This car is "new to me", so I know nothing of it's history. I did buy it from the original owner who allowed he "wasn't much for maintenance". 115K miles. I just got it home a few days ago. It required the immediate replacement of a coil, while I was at it I decided to replace the plugs. When I took off the cover, I noticed oil in the valley between the cams. This seemed to be mostly near the "rear" camshaft. As I pulled the plugs (I assume they were original), I noticed that 1-4 were saturated with oil.
Is this condition at all normal? Does it result from spill at the oil fill? Is there a cure?
Oil in my valley '04 V70 NA
- Been thanked: 4071 times
I get this on top of my 1999. It comes from the oil filler cap, so you can try a new gasket to try reduce it. It helped a bit on mine. The best test is clean it off with paper towels, remove the plastic cover , and watch the top to see how the oil accumulates...if it starts at the middle front and works outwards it's the oil filler cap
Faust
- Year and Model: xc70 2008
- Has thanked: 31 times
- Been thanked: 10 times
An ethical question. When I cleaned out the console, I found three ladies Timexs and a Rolex. Do I keep the Rolex?
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
If you do, some gets your soul. You should know that.
Seriously, call the PO. Only good can come out of that.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
Put it like this:abscate wrote: 02 Dec 2018, 16:08 If you do, some gets your soul. You should know that.
" what do you want me to do with these crappy old watches"
- BlackBart
- Has thanked: 967 times
- Been thanked: 922 times
Wasn't "Oil in my Valley" a sweeping epic western based in Texas....?
- Has thanked: 311 times
- Been thanked: 817 times
A Faustian bargain plays out right here on MVS!
Paramount point about the oil in the valley: given the history I would immediately suspect it is due at least in part to a clogged PCV, and do a glove test.
Faust
"Wasn't "Oil in my Valley" a sweeping epic western based in Texas....?"
Not sure, the phrase simply sprang full blown in my mind, much like Venus from a Cypriot sea.
2004 V70
- 1229 Views
Last post by 850 LPT
- 2172 Views
Last post by fitz548
- 1523 Views
Last post by tryingbe
- 3860 Views
Last post by FlyingVolvo
- 64 Replies
- 25223 Views
Last post by prwood
