Okay vital stats: 2004 s60 T5 AWD with 208,000 miles. Length of ownership, maybe a month. Came with CPS, TPS, and MAF codes and a check engine light.
So far I have replaced the CPS and TPS and replaced plugs (last step was probably a waste the plugs I took out looked good). After replacing the CPS I noticed no change. After changing the TPS I noticed a BIG change, much better throttle response and much smother shifting. I am however still getting at least 2 reduced performance messages on almost all drives. I am NOT a mechanic and know zip about Volvos, any idea on what else could cause this error? It seems to trigger when coming off low/no throttle and rolling onto it. One strange note, the error doesn't seem limit performance much if any. Even when the CEL was on the car seemed to run well. After installing the plugs I removed the neg terminal on the battery and clear all codes. With in 40 miles it through another CEL, haven't had the codes read yet. Hoping to find a scanner to borrow that might provide more info than the one at the auto parts store. Any help is appreciated I'm very frustrated at this point.
CEL and reduced engine performance
- Has thanked: 1614 times
- Been thanked: 4078 times
You won't progress until you get the codes read, and preferably the Volvo ECM-zxxxx ones
After 40 miles I would guess that's an EVAP code but guessing is really pointless
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
The "reduced engine performance " message usually is in relation to brake booster system ...maybe brake pedal sensor(also power booster sensor) or booster vacuum switch or hoses to and from vacuum switch. Factory codes.curt698 wrote: 04 Dec 2018, 19:51 Thanks, I have a scanner coming from Amazon Thursday. I will report back my findings then.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
That is interesting info. I got my Bluetooth scanner yesterday and installed the Torque app. I'm still learning how to read and configure the app but yesterday it showed a LOT of Vacuum and very little boost. I guess that is expected for a 14 year old car with almost 210k miles. The good news is that I'm down to just one fault now. I'm still get a Crank sensor low volt code. Hope to pop the hood and find the cause of that tonight.shiloh51933 wrote: 07 Dec 2018, 07:45 The "reduced engine performance " message usually is in relation to brake booster system ...maybe brake pedal sensor(also power booster sensor) or booster vacuum switch or hoses to and from vacuum switch. Factory codes.
- shiloh51933
The brake system codes aren't regular DTC issues, you have to have ability to team OEM trouble codes and/or ability to read ABS system codes.curt698 wrote: 07 Dec 2018, 07:54That is interesting info. I got my Bluetooth scanner yesterday and installed the Torque app. I'm still learning how to read and configure the app but yesterday it showed a LOT of Vacuum and very little boost. I guess that is expected for a 14 year old car with almost 210k miles. The good news is that I'm down to just one fault now. I'm still get a Crank sensor low volt code. Hope to pop the hood and find the cause of that tonight.shiloh51933 wrote: 07 Dec 2018, 07:45 The "reduced engine performance " message usually is in relation to brake booster system ...maybe brake pedal sensor(also power booster sensor) or booster vacuum switch or hoses to and from vacuum switch. Factory codes.
- 13 Replies
- 1651 Views
Last post by firstv70volvo
- 6270 Views
Last post by oragex
- 14 Replies
- 7255 Views
Last post by raquette
- 3020 Views
Last post by mickenann
- 1783 Views
Last post by carlsson72
