Hi Everyone,
Six months ago I changed my Brake Pedal Position sensor (https://www.ipdusa.com/products/16513/1 ... ion-sensor) because it was leaking and started to give me ECM-900C code once in a while.
Is it possible that the unit is broken again or is my BCM going bad? Is there any other way to test it then getting a new sensor? This is my daily driver..
Here are ViDA graphs:
All the codes:
Details for ECM-900C:
Details for BCM-0147:
Here is a graph from BCM of the position sensor. After about 40s the values froze but I'm not sure if it was because ViDA disconnected or because of the sensor. I might repeat this again.
Thanks for your input!
06 S60 Brake Pedal Position Sensor going bad after 6 months? Topic is solved
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Remove the electrical connector and inspect for any corrosion and for female terminal tension. You can use a paper clip and hammer it to flatten it to be the same approximate thickness as pins in the sensor and then insert it into connector and see if falls out on its own and also if there is felt drag is you try to pull it out. Usually a comparative test can be made on any multiple terminal connector as they will usually not all have the problem.
If all is oK there then it could just be a bad part, it happens.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Quality: aftermarket
Get a used genuine one off ebay & make sure its secured properly in place with the circlip
zjevik
- Year and Model: S60 2006
Sorry for such long break. I had to do PCV system and didn't have time to get to this.
It looks like jimmy57 was right. I cleaned the terminals and everything looks good. The cruise was disabled on most of my drives before but it's been working good for the past week. I'm a professor so let's see if it's going to last through this coming semester.
- 5259 Views
Last post by precopster
- 2563 Views
Last post by jimmy57
- 3458 Views
Last post by afa7afa7
- 5114 Views
Last post by Raindog92
- 3810 Views
Last post by Goldchemist
