Thanks for not waking us up.
- Has thanked: 1613 times
- Been thanked: 4078 times
- Has thanked: 317 times
- Been thanked: 531 times
I would definitely recommend at least checking that wiring anyway. I didn't have anything more than a funky trunk lock (wouldn't disable the alarm if I unlocked with the key) on my GLT and I had multiple cut wires back there.abscate wrote: 01 Dec 2018, 01:30 Bruno...completely forgot to point you to the rear hatch wires as a potential cause for a no crank. Check Fuse number 6 ( maybe?) for central locking and see if it's blown. Tha one goes when the wires in the hatch hinge break on driver side, and will lead to a no crank.
- jvl
- Year and Model: 2006 V70 2.4D
- Has thanked: 20 times
- Been thanked: 8 times
Installed my remanufactured propshaft.... but now there is a whining noise coming from the front end, most noticeable at 40 mph! Could this be the angle gear? The sleeve/collar was already plug welded in about 25k miles ago.
Any suggestions welcome.
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Check and verify you don't have tires on one axle that are excessively worn compared to the other axle. It (at least on mine) caused this noise.jvl wrote: 02 Dec 2018, 06:01 Installed my remanufactured propshaft.... but now there is a whining noise coming from the front end, most noticeable at 40 mph! Could this be the angle gear? The sleeve/collar was already plug welded in about 25k miles ago.
2023 Lexus RZ450e -66k
- jvl
Thanks.
I will flush the angle gear oil a few times. From what I've read, this can also help with the noise.
I installed four new tires about 35k miles ago and rotated front to back once since then. Will re examine.
Thanks again!
Thanks again!
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
Thanks, gents! The remote starter wire has ~12.6V, central locking fuse looks OK, and the rear hatch wires appear intact. I was looking at this thread, which suggests checking the PNP switch next: viewtopic.php?f=1&t=86888&start=10bmdubya1198 wrote: 01 Dec 2018, 07:44I would definitely recommend at least checking that wiring anyway. I didn't have anything more than a funky trunk lock (wouldn't disable the alarm if I unlocked with the key) on my GLT and I had multiple cut wires back there.abscate wrote: 01 Dec 2018, 01:30 Bruno...completely forgot to point you to the rear hatch wires as a potential cause for a no crank. Check Fuse number 6 ( maybe?) for central locking and see if it's blown. Tha one goes when the wires in the hatch hinge break on driver side, and will lead to a no crank.
Also, I looked at the '99 V70XC and the '98 V70 relays and discovered that they were different part numbers. When I looked at the '00 V70, I found that it had no relay in the starter position — and yet it starts like it's brand new. What gives!?
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Welcome to ME7. It's for the cool guys.
brunocerous
Frustrated with the no-start in my '99 V70 XC, I pulled the replacement starter, tested it, and learned a lesson: Don't automatically trust used parts. A new one is on order.
Well, with any luck a new one will get the car going!brunocerous wrote: 06 Dec 2018, 14:09 Frustrated with the no-start in my '99 V70 XC, I pulled the replacement starter, tested it, and learned a lesson: Don't automatically trust used parts. A new one is on order.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Finally got some time to undo my heater core bypass and get some heat back with the whole winter thing happening. However I ran into a snag. My buddy bypassed the heater core some time ago and all he could tell me was that the clips disintegrated. I bought new clips and found that the lower port will not "snap" in place no matter how hard I push. I took a picture with my phone and I don't believe I see any "sleeve" with slots for the clips to snap into. The top port does have the sleeve so I think maybe it came out with the clip when he removed the hoses. Can some confirm this?
