Has thanked: 1613 times
Been thanked: 4078 times
I seem to recall the clips in my kit were too long. If you go way back my history to 2013 that's when I did my AC and heater core on my T5, I think I wrote it up then
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
I've had 5/8" brass 90 degree hose barbs connecting two heater hoses through each hole in the firewall for about four years now. No clips, no o-rings, no leaks. I'd guess the original design is an artifact of the vehicle assembly process, or maybe to accommodate different hose routing for turbo and NA models, though I'm not aware of any differences in the heater hoses.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
abscate wrote: 07 Dec 2018, 00:07 I seem to recall the clips in my kit were too long. If you go way back my history to 2013 that's when I did my AC and heater core on my T5, I think I wrote it up then
I did remove what was left of the old rings and spacers since the newer design incorporates a spacer. Looking at pictures of the junction on fcp shows there is definitely a sleeve missing. I've ordered a replacement.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Yep, that's broken. Same thing happened to my cousin's S70. You're either going to have to connect those hard lines to the heater core hard lines with some good coolant hose or you'll have to replace that junction box in its entirety.
There's a really good writeup on here about doing the alternate method. viewtopic.php?f=1&t=68158
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
Today, I installed the new starter in the new-to-me '99 V70 XC but don't seem to be getting power at the green wire. Relays are getting power all right, but I think I may have broken the green wire at some point while getting the old one out.
I got no click upon cranking but hear a "sproing" when turning the key off, and it seems to be coming from the area around the passenger side door.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
bmdubya1198
brunocerous wrote: 07 Dec 2018, 13:24 Today, I installed the new starter in the new-to-me '99 V70 XC but don't seem to be getting power at the green wire. Relays are getting power all right, but I think I may have broken the green wire at some point while getting the old one out.
That's funny, I get the same springy noise in my R. I've never had that in any of the other 4 P80s I've dealt with.
It sounds like it's coming from the console. It's really weird.
bmdubya1198
I also came across this gem at the junkyard today. Spot the problems...
brunocerous
That's hilarious! It's like those kids' activity books where you have to find what wrong with this picture.
I think the screw (and the "vent") in the PCV hose is my favorite. The wire-activated turbo waste gate (?) is a close second.
Was the upper mount "repaired" with a plunger?
bmdubya1198
brunocerous wrote: 07 Dec 2018, 13:48 That's hilarious! It's like those kids' activity books where you have to find what wrong with this picture.
Hahaha, I didn't even see that! That could explain the film of oil over everything!
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
bmdubya1198 wrote: 07 Dec 2018, 13:33
Believe the sprong noise is the airbag temporary power module. Haven't pulled one apart but believe it is similar to an old flash where a capacitor charges up and then as you turn it off, it is setup to intentionally discharge in a controlled manner.
2023 Lexus RZ450e -66k
