Motul oil doesn't burn
June
Has thanked: 523 times
Been thanked: 261 times
Re: Motul oil doesn't burn
Post by June »
Sommerfeldt wrote: 03 Dec 2018, 04:01
June wrote: 03 Dec 2018, 03:36
Rattnalle wrote: 03 Dec 2018, 01:58 Synthetic oil and leaks isn't only about seals failing. It's as much about better cleaning properties and less buildup of the solid crud that's kept an already worn out engine from leaking by plugging the holes.
The two Volvo fives with 200k plus miles that I've owned both used very little oil, a litre or so every 10' miles at most. Both using synthetic. Neither was serviced excessively but rather by the book once a year or so.
Is it safe to say over there in Sweden all synthetic oil is group 4 or 5 100% synthetic? So those two 5cyl 200k cars actually ran 100% synthetic oil?
My engine is a testimony that even with 3K oil changes group 3 "fully synthetic" crap we are sold over here creates deposits inside the engine which clearly is visible under the oil cap of my car. I find it criminal that the oil companies were allowed to change the product without posting a warning label on the bottle or at least change the label enough that the difference is noticeable.
After reading endless debates on here then noticing the crud under the oil cap back in 2016 I researched the subject and realized I could have saved a ton of money and simply let the dealer put in GTX and probably ended up with the same crud at half the price! So I finally made a informed decision 13 years late and switched my engine to Redline a group 5 oil which gave a noticeable difference immediately as the engine is noticeably quieter. Amazingly enough you are correct in that slowly the crud is dissolving under the oil cap now that my engine is actually running a real synthetic oil. June
The cleaning properties come from additives in the G3 oil, as well as the processes it's put through. I think it's plausible that aside from the "excessive" cleaning, those may have had a detrimental effect on seals in the early days, though like I said, I've seen far less of those "I switched to synth and now my car's a ball of fire at the roadside" claims the last couple of years.
Swedish (and Norwegian) oil is basically the same as you get in the US. The fluid in a bottle of Mobil 1 5w-50 isn't different here, at least not according to the MSDS's that I've seen. I'm curious about the G5 oil though - how do you know what that is? I can see switching to a G4, like Motul, but the G5 is just a "various other stuff", mostly additives as far as I can tell (though my knowledge base on this is far more lacking than I thought ;) ).
- S
The G5 oil I have been using since October 2017 and 146K is Redline 5W30 which is Ester oil. Ester is added to most G3 and G4 oils as additive to give cleaning and multi grade properties. Redline being Ester is naturally clean and multi grade so they don't add group 4 or 3 to it. This is what I understand from all the reading I have done on the subject.
So my car new to 146,019 miles, December 2003 to October 2017 ran 3K oil changes with G3 dealer full synthetic Castrol and nasty crud built up under the oil cap and shining a bright flashlight through the grates the head looked nasty with build up. I am not impressed at all with G3 oil. May as well go cheaper with dino in my opinion and save your money after all dino is G3's base.
Thinking about what you and others have said about synthetic oils cleaning gunk I was curious to see what actual 100% synthetically made oil has done in 27K and one year still 3K oci. So peaking through the grates today all viewable head surface is bare aluminum silver color. The bits of the cam also looks clean. I am shocked! Last year everything viewable was brownish with gunk and no metal could be seen. Also cam was completely covered with gunk streaking to silver on the lobe tips. Now looks clean... The only change was going from G3 Castrol to G5 Redline, dealer still changes it for me so same genuine Volvo filter used. Impressive! June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Has thanked: 293 times
Been thanked: 765 times
How many miles per year did you drive that car before Oct 2017? Curious about the apparently high sludge levels.
To be fair, plenty of engines on group 3 oil are not badly sludged up. Probably most of them.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
June
Post by June »
erikv11 wrote: 07 Dec 2018, 22:25 How many miles per year did you drive that car before Oct 2017? Curious about the apparently high sludge levels.
From 12/2003 -03/2016 new-109K so many of those years were driving a few miles per day as a kid taxi. 03/16-now 109K-173K a lot of highway miles. Note less than 1/2 of the last 2.75 years/64K the engine has been running a group 5 oil and yet the crud has incredibly been melting away, I am truly shocked. That was not happening with the group 3 dealerships oil driven under the same mostly highway conditions from 109K to 146K. Clearly the group 3 Castrol does little to dissolve sludge compared to the group 5 Redline.
I hate to think how bad it would have been with the 7,500 mile factory recommendation. Really I am ticked off that Volvo would screw so many customers over by recommending crap oil and long oil changes. Here I thought I was keeping my car's engine clean with real synthetic oil completely unaware the greedy oil companies were ripping everyone off with tricky wording which was deemed legal.
Even worse is the 10K oci for the new Volvos! No wonder they removed the oil dipstick...
Like me, all of you have your preferences on oil. One thing I can tell you is in the 80s and 90s when synthetic oil was actually that, synthetic. Oil stayed perfectly clean between changes then the thousands came and that was no longer the case as per my observation. I started with Mobil 1 in 1986 and was extremely happy with their product for years. Now I can safely say I am extremely happy with Redline. June
My Volvo cars owned
1996 960 ordered
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
The new Volvos all require a Volvo specific oil rating and the previously unusual 0w20 viscosity. I don't think there's much room for adding anything other than what they designed the engine for there.
As for colour the oil is supposed to go black as it collects soot and other contaminants, doing it's cleaning duty. It's not ideally supposed to add to the blackness itself though.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
I've done 3-5k mile oil changes over the last 40k miles with non-synthetic oils off the Walmart shelf, and I've got no crud built up anywhere. There was nothing gunked up over the lifters when I pulled the cams maybe 10k ago. The previous owner (30k or so, I believe) was not using synthetic oil either.
Has thanked: 1506 times
Been thanked: 3822 times
I did 5000 mile OCI Castrol Dino oil on my T5 for most of its life , at 160k the PCV was clean and unclogged.
I switched to synthetic And run 7500 miles now
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Thanks for the reply, June.
We’re never going to hit a finish line in the oil debate races, but I think it’s safe to say that realizing G3 and the oils we usually put in our engines aren’t really synth can be useful. I for one am also definitely going to check out Motul or Redline, and see what they do on my engine. While it’s always clean, I’d be interested to see what they can do with the “patina” I think we all can admit to seeing when we peer into the oil filler hole...
- S
[Sold] '97 S70 T5
I'm guessing the boost levels have a big impact on sludge buildup. I drove my car for a year with the turbo hoses wrong and didn't notice. My friend in Florida, diplomatically, may boost more.
I just hit 5000 on my Mobil 1 high mileage and might run Blackstone on it to see how it looks vs 7500.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
abscate wrote: 08 Dec 2018, 05:27 I just hit 5000 on my Mobil 1 high mileage and might run Blackstone on it to see how it looks vs 7500.
The M1 HM is pretty good stuff. I ran a 10,000 mile OCI and did a Blackstone test with nothing really flagging except silicon (which I think was from me screwing with the intake hoses or filter at some point).
I've been running Liqui-Moly 5W-40 now for a couple years on 7,500 mile intervals.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
June
Post by June »
I found a photo here on MVS I posted here on MVS 03 2017. Took the others today. It is hard to get a photo in between the grates. Last year the bottom of the oil cap was completely caked with hard dark brown deposits which are melting away on their own the same thick brown deposits were coating the inside of the head. Obviously the grates prevent a lot of the splashing action of the oil that must be why the inside of the head looks so dramatically better than above the grates. The grates themselves look better and the portions angled inward also now are bare metal. To my knowledge nobody has scraped the hard deposits off the oil cap. Same dealer doing my oil changes as always and my engine has not been opened.
Last year when I shined the flashlight through the grates no hint of aluminum could be seen, just dark thick crud could be seen. So in one year of oil changes; this much difference is way beyond my wildest expectation. Notice the light reflects off of the head's interior. In person silver aluminum can be seen as of today. June
My Volvo cars owned
1996 960 ordered
