2007 XC90 Expansion Tank
Quigs11
- Year and Model: 2007 Volvo XC90
I have a Volvo xc90 with a leaking expansion tank. I found a replacement 30741973 but it only has one nipple connector on the top of the tank and my old tank 30760100 has 2 nipple connectors on top. Can I "T" one hose into the other hose and connect to the nipple connector?
- Been thanked: 504 times
If you are creative enough, then I guess you can do a T to save money since you already have the new reservoir with only 1 nipple.
https://www.ipdusa.com/products/6965/11 ... nsion-tank
- SuperHerman
- Been thanked: 207 times
I don't have your year or engine, but on my 2004 T6, I believe one side takes coolant in from the thermostat housing and the other side serves as a vent hose which may run to the radiator (don't recall).
If this is the set up on yours I don't think it will work.
If one hose has liquid flowing in and the other is some sort of vent a single port will cause a conflict.
Start your engine and have a look.
- 598 Views
Last post by MistyB
- 22 Replies
- 3667 Views
Last post by rspi
- 884 Views
Last post by tryingbe
- 1367 Views
Last post by beigg
- 954 Views
Last post by bluesquirrel
