'94 940 speed sensor - wanted - P/N 1398321
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
DrJammer
Year and Model: 2000 V70XC - 195k
Post by DrJammer »
Hey all, I am looking to help a fellow Volvo owner and I wasn't getting as many views in the classifieds. No speedo movement and the odometer is spinning like the Tasmanian devil. Trying speed sensor before going into the dash cluster.
Looking for this:
Hello MVS community - I am trying to locate a rear speed sensor for a friend. We are not certain of the speedometer issue. I have done some sparse diagnostics and would like to try swapping in a used, working speed sensor to see what happens.
I believe the P/N 1398321 can come from the following:
Vehicle Fitment: Volvo: 740 1989-92 | 760 1989-90 | 780 1989-91 | 940 1991-95 | 960 1992-97 | S90 1997-98 | V90 1997-98
I just don't want to buy a new one until I am sure that is the issue.
Please message if you have one for sale. Thank you
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
DrJammer wrote: 14 Dec 2018, 19:33odometer is spinning like the Tasmanian devil....a rear speed sensor for a friend.
Uh, unplug it....is there a change?
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
I'm thinking the cars you have listed use an impulse converter between the speed sensor and the speedometer. It's location on my 88 765 is under the drivers side dash near the kick panel. When you locate it you'll know as it has a red fuse plugged into it.
1988 Volvo 760 Turbo Wagon
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The 87 and 88 with ABS had to use a 96 pulse reducer converter due to the ABS using a much higher tooth count than the non-abs, 89 and later used 48 tooth tone rings and the speedo system was altered to use that input signal as is.
DrJammer
Post by DrJammer »
Hmmmm, I think I got that info from FCP. Will have to be careful upon ordering.
I unplugged the sensor and the odometer stopped rolling as well. Is it safe to say a new sensor is the remedy?
Ex-Volvos
2008 S60 - leased
93Regina
Post by 93Regina »
DrJammer wrote: 17 Dec 2018, 05:56Is it safe to say a new sensor is the remedy?
If the "Tasmanian devil's" rhythm is proportion to vehicle's momentum, his dance may be upstream.
Defuse ABS power, as one experiment....turn on lights, and change from low to high beam, as another experiment.
DrJammer
Post by DrJammer »
I am definitely not an electrical guru, not too familiar with the 94's, so I am not following completely.
speed sensor is unplugged and speedo doesn't work (duh), and odometer does not turn.
So I turn on the lights and fiddle with the high/low beams as an experiment. Am I seeing if there is a dash cluster issue?
Ex-Volvos
2008 S60 - leased
93Regina
Post by 93Regina »
DrJammer wrote: 17 Dec 2018, 07:36so I am not following completely.
Differenital's speed sensor "feeds" ABS and speed-o/odometer gauge. All that has been done so far is too show sensor's signal is working.
ABS unit may be creating a signal pulse...so remove its power. Also, each front-wheel sensor might be disconnected...I'd do both first.
On a Volvo semi-truck, flipping the headlights to high beam energizes speed-o to show false readings. So, with lights out...observe odometer's rotational speed at a given vehicle speed, then turn on low-beams, and observe, and then high beams.
lummert
Post by lummert »
If odometer was working with the speed sensor connected but isn't working with speed sensor disconnected the problem is most likely not the speed sensor. Perhaps the issue is the speedometer itself.
DrJammer
Post by DrJammer »
Thanks for the input so far. The car is across town, so I don't get to fiddle with it often. The fella drives about 1000 miles a year and was getting fired up when the odometer started churning.
I am not sure what to do after I try cleaning the front sensors and unplugging ABS and do low/high beam test.
I don't think I am up for soldering, repairing the speedo. Will a cluster replacement take care of this, if it is the speedo?
Ex-Volvos
2008 S60 - leased
