We had another user mentioning the same issue with the cabin air, right after replacing the car battery.
As mentioned above, I would perhaps try first recalibrating the CCM (Vida)
But I'm also thinking at a busted cabin temp sensor (tiny guy behind the grid near the right temp knob).
When connecting the car battery, Volvo procedure calls for the ignition key to be placed in POS II - headlights on on cars with daylight running lights. So all cars should have the headlights on when reconnecting the car battery (I also do this when disconnecting the battery because sometimes I get sparks at the poles).
This prevents a power burst in the car electronics, namely a tiny thermistors is sensitive to this and can fail. Possible the cabin temp thermistor got damaged and may work for a little until it warms up then opens the circuit.
Interesting Climate Control Behavior Topic is solved
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Rattnalle wrote: 25 Oct 2018, 03:06You shouldn't turn the AC off though. That button is only useful when driving with the windows down in summer.abscate wrote: 25 Oct 2018, 02:29 It should be sticky, that is, if you turn off the AC manually, the next time you use the car it should stay off.
The defrost mode always turns on AC
But yes it should stay off if you do turn it iff.
It is indeed a good idea to run the A/C all year around, even in cold weather (the A/C cold air is mixed with the hot air). This helps lubricate the A/C system o-rings with the A/C oil and keep these seals flexible and prevent leaks. I usually run it weekly once, then stop it a few minutes before parking the car, to allow the evaporator to dry - otherwise it builds up mildew and starts smelling (some cars have a setting to run the blower after shutting off the engine to dry the evaporator, but mine doesn't have it)
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Afaik the main reason is that it's dangerous if the airbag goes off when power is restored. Better not sit behind the wheel then.oragex wrote: 19 Dec 2018, 11:16 We had another user mentioning the same issue with the cabin air, right after replacing the car battery.
- Rattnalle
The blower running for a bit is a configurable user parameter in vida. I've turned it on to keep the system fresher. It'll use more battery though.oragex wrote: 19 Dec 2018, 11:19Rattnalle wrote: 25 Oct 2018, 03:06You shouldn't turn the AC off though. That button is only useful when driving with the windows down in summer.abscate wrote: 25 Oct 2018, 02:29 It should be sticky, that is, if you turn off the AC manually, the next time you use the car it should stay off.
a3inverter
- Year and Model: 2006 V70
- Been thanked: 9 times
Yep, my DRLs are on all the time. I'll look at the thermistor under some bright light next chance I get.oragex wrote: 19 Dec 2018, 11:16 When connecting the car battery, Volvo procedure calls for the ignition key to be placed in POS II - headlights on on cars with daylight running lights. So all cars should have the headlights on when reconnecting the car battery (I also do this when disconnecting the battery because sometimes I get sparks at the poles).
- oragex
It may or may not be apparent. If its resistance element got weaker, it won't show up physically. I think it's a 10k ohm at room temp (25C) but not too sure
a3inverter
Update: It seems to have fixed (or recalibrated) itself. This behavior actually mimics what I recall from the first time I pulled the battery cable. Nice heat for my full commute (and any longer drive) now.
- Been thanked: 504 times
- Thermostat may be bad. I use Wahler, info in forum.
- The dial setting is probably normal, if I turn the knob 3-4 mm from RED, I get luke warm air.
a3inverter
Now that the weather has turned colder here in New England, I have found that my climate control isn't working as expected. Perhaps I spoke too soon in January
Conveniently, I have VIDA/DICE now and found last week that the CCM was consistently throwing a CCM-0006 Fan Motor Passenger Compartment Temperature sensor Signal too high/Signal missing fault.
The sensor itself seems to be working fine as it was detecting changes in temperature (via VIDA) as I turned the temp knobs up and down.
I pulled the CCM yesterday (following all appropriate battery disconnect procedures) and found that the Temp Sensor Fan wasn't clogged and did spin freely. The channel rearward to the thermistor/temp sensor was clear as well. It had vacuumed this out about a year ago and got a big ball of dust out of it. I managed to rig things up so I could get the car running and see the fan in action and voila! the fan was not turning in Auto mode which seems to relate to the CCM-0006 fault.
Going to hit the junkyard next weekend to see if I can get a used Temp Sensor Fan (best price for a new one seems to be between $140-180 USD)
Went for a drive after I got it all back together again and In Auto mode, the main climate blower fan will increase in speed and output as I move the temp knobs up and down. This seems to be the expected behavior. Heading out for a ride now with my instant read cooking thermometer to see how the behavior changes during a 30 minute drive. The previous behavior was that everything worked great for the first 15 minutes or so, then started to blow cold air.
a3inverter
Based on the readings from my thermometer, with a knob setting of 72 (right in the middle), there was a steady rise in temp from 46F to 127F over the first 12 minutes of driving around, then the temp began to drop, getting to 81F by 22 minutes of driving.
When I increased the knob setting to 76, the temps increased again for a short time but then began to fall just as quickly.
Turning the knobs to full heat (which I understand to be an "override" setting) the temp got back up to 130F.
Here's my hypothesis:
Given that the purpose of the little fan behind the CCM is to keep the air directed at the temp probe constant while the CCM and surrounding electronics generate heat and thus increase the ambient temperature of where the temp probe lives (this purpose I have come to understand from reading here and other sites), and given that my fan doesn't appear to be functioning, I hypothesize that as the ambient temp around the sensor increases, it signals to the CCM that the cabin is hotter than it really is. The CCM in turn does the appropriate things to attempt to reduce the temperature of the cabin.
Once I get a new fan in place, I'll run the test again.
