Chassis Battery affecting Cruise Control
- firestarterpro
- Year and Model: 850 NA - 1995
- Has thanked: 2 times
I have an amazing
._____________,
||------|---||---||__\ \___
\=-(@)-===-(@)-=*B
The proudest owner of a Naturally Aspired 2.4L Volvo 850 Wagon of 1995!!!
94 850 NA Wagon was hit and totalled at 350k
96 850 NA Sedan sold at 180k
95 850 Turbo Wagon sold at 260k for parts
95 850 NA Wagon sold at 220K
\=-(@)-===-(@)-=*B
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 73 times
Go on...?
I'm not missing something right?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- ZionXIX
- Has thanked: 64 times
- Been thanked: 194 times
I'm invested now
- FireFox31
- Has thanked: 158 times
- Been thanked: 300 times
"Despite the negative press cruzcntrl..."
FireFox31
- Has thanked: 1503 times
- Been thanked: 3817 times
FAcebook has decided to censor your posts
- firestarterpro
Lol.... Put my phone in my pocket mid-message and forgot about it.
I have an amazing [i think that was an auto-correct typo, but I'll go with it] additional chassis deep cycle battery (800 CCA) I installed to power rgb led accent lights I leave on 24/7.
It also powers my radio and subwoofer/amplifier independently from my main battery. I installed a breaker switch after the inline fuse, so I can quickly disconnect the chassis battery, from the main circuit, when I exit the car.
I play Christmas music all night until the battery dies... Which is around 2 am.
Im the new old-fashioned leaving christmas exactly where it was.
Each morning, when the engine is started, it takes 5 to 10 seconds for the RPM to idle at just above 1.0 RPM. After I close the circuit (connecting the 2nd battery) the RPM drops to 0.9 RPM. I believe it should be at 8.5 naturally. Which means I have problems outside of the chassis battery.
Nonetheless, an additional problem arose when going from DC to Delaware today. After leaving the cruise control on for more than an hour, i got three check engine codes in my OBD-I. The engine idled high in neutral [stick shift] at around 1.7 rpm after the code.
A-4
TPS Sensor Voltage
A-2
TPS Sensor Voltage (again)
Camshaft Sensor Signal Missing
I cleared them both, drove home without using cruise and the code didnt come back yet.
For the idle being slighty high, I think my alternator bushing needs to be replaced, which I just ordered since the car is over 200k.
It just bothers me that the idle changes when I connect the second battery.
I bought a voltage display for each battery so can monitor how much they fluctuate with changes in the circuit. (Starting, turning on the radio, connecting the 2nd battery.)
Also, im going to add the "Big 3 Ground Wires" under the hood as well as an additional one for the 2nd battery in the back.
I think, in writing it out, I may have found a solution to my problem. Nonethess, I will hit submit.
A-4
TPS Sensor Voltage
A-2
._____________,
\=-(@)-===-(@)-=*B
\=-(@)-===-(@)-=*B
- jvl
- Year and Model: 2006 V70 2.4D
- Has thanked: 20 times
- Been thanked: 8 times
Don't be bothered by the changing idle: when you connected the 2nd battery, it will draw afirestarterpro wrote: ↑19 Dec 2018, 20:36
current (a big current when the 2nd battery is flat) which will cause the alternator to turn 'heavier', so the engine simpy has to deliver more torque to provide this energy.
Adding extra grounds might be good.
Also, check that the cable that runs from the alternator to your 2nd battery is as short and as thick as possible: less resistance in this cable will help keeping voltage drops to a minimum and help improve overall charging efficiency.
Adding a big (100 or 150 amps) fuse is never a bad idea.
Joost
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
