has anyone on here opened up there front signal lights?
NYCKID221
Year and Model: 1998 s70
Post by NYCKID221 »
if theres a method please chime in. im looking to diy them to match my diy blk housing headlights
ive tried using my heatgun and no luck.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Heatgun,flat screwdriver and a lots of patience.
Not enough heat...it will crack.
More than enough heat....it will melt.
Assembly is glued...even if you open it....you will need to find a proper glue to close it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
NYCKID221
Post by NYCKID221 »
heatgun method doesn't work
jvl
Year and Model: 2006 V70 2.4D
Has thanked: 20 times
Been thanked: 8 times
Post by jvl »
I did it using lots of hot water and a plastic screwdriver to wiggle the lenses off of the housing.
Leave the entire assembly sitting in a bucket of hot water for a while, then try prying of the lens.
I then cleaned the housing and put it back together using a hot glue gun.
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I had one fall off and reassembly was fairly easy with clear silicone caulk. If you can get them apart intentionally be sure to leave the weep holes on the bottom open when you glue it back together.
jvl
Post by jvl »
Great tip on the weep holes, Lee.
I did take notice on mine but forgot to post that here.
NYCKID221
Post by NYCKID221 »
no luck with hot tap water.
Has thanked: 1609 times
Been thanked: 4065 times
Heat gun and perseverance. Its like opening and iPad - too much, broken glass, too little,broken glass.
misha
Post by misha »
abscate wrote: 08 Jan 2019, 14:22 Heat gun and perseverance. Its like opening and iPad - too much, broken glass, too little,broken glass.
:mrgreen: :mrgreen: :mrgreen:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
NYCKID221
Post by NYCKID221 »
using the heatgun is not the same as opening headlights and resealing headlights. i don't know what glue they use on the corners and don't want to break them.
