if theres a method please chime in. im looking to diy them to match my diy blk housing headlights
ive tried using my heatgun and no luck.
has anyone on here opened up there front signal lights?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Heatgun,flat screwdriver and a lots of patience.
Not enough heat...it will crack.
More than enough heat....it will melt.
Assembly is glued...even if you open it....you will need to find a proper glue to close it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- jvl
- Year and Model: 2006 V70 2.4D
- Has thanked: 20 times
- Been thanked: 8 times
I did it using lots of hot water and a plastic screwdriver to wiggle the lenses off of the housing.
Leave the entire assembly sitting in a bucket of hot water for a while, then try prying of the lens.
I then cleaned the housing and put it back together using a hot glue gun.
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
- Year and Model: Many Volvos
- Been thanked: 76 times
I had one fall off and reassembly was fairly easy with clear silicone caulk. If you can get them apart intentionally be sure to leave the weep holes on the bottom open when you glue it back together.
- jvl
Great tip on the weep holes, Lee.
I did take notice on mine but forgot to post that here.
Heat gun and perseverance. Its like opening and iPad - too much, broken glass, too little,broken glass.
- misha
abscate wrote: 08 Jan 2019, 14:22 Heat gun and perseverance. Its like opening and iPad - too much, broken glass, too little,broken glass.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 2214 Views
Last post by E Showell
- 11 Replies
- 5875 Views
Last post by Ozark Lee
- 11 Replies
- 3776 Views
Last post by equiprx
- 1367 Views
Last post by beigg
- 926 Views
Last post by mrbrian200
