'94 940 speed sensor - wanted - P/N 1398321
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
DrJammer wrote: 18 Dec 2018, 13:10not sure what to do
1. unplugging ABS's power via fuse
2. front sensors
3. do low/high beam test.
Then, report back....dangling conversations were for Simon & Garfunkel
DrJammer
Year and Model: 2000 V70XC - 195k
Post by DrJammer »
Yes, I agree on dangling conversations. It's holiday time, we are getting about an inch of rain an hour, and the car is 20 minutes away from me.
I thank all for their patience in trying to assist me.
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
DrJammer
Post by DrJammer »
To confirm, I am doing the 3 steps below with the rear speed sensor still unplugged? Or do I plug that back in? Again, I am not super familiar with this '94 and may need explicit direction.
2. front sensors
Ex-Volvos
2008 S60 - leased
DrJammer
Post by DrJammer »
Ok I'll do my best to relay my steps in order in the odd case they help someone out. With rear speed sensor out., I removed the ABS. Fuse. then I cleaned the front sensors . Then drove around block with rear sensor out. No action from anything. Then took a ride after plugging in rear sensor. Fronts cleaned, ABS fuse out, the same symptoms. No speedo, tach is fine, odometer and trip meter are going 3x the rate. No alterations when changing from no lights to low to high
Have chance to be near someone with 940/960 parts in the next week
Ex-Volvos
2008 S60 - leased
