Hey guys,
It's not something I did tot my S70, but something I noticed driving today. The engine idles just fine, without anything noticeable. But when I accelerate from 1st to 2nd gear or from 2nd to 3rd, it hiccups a bit, you can feel the engine stall a bit. I know it's a lot to ask giving so little information, but I'm curious, maybe you guys can help me start to troubleshoot this hiccup.
It's a 2.5 engine with 10 valves, the B5252s from 1998. I have changed all filters, but have not looked at the spark plugs or wires.
Hope to hear from you guys!
1998 S70 10 valve M56 tuneup, stutter at mid rev
- Ocelot
- Year and Model: 1998, S70
- Has thanked: 61 times
- Been thanked: 17 times
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Recent car
- Has thanked: 316 times
- Been thanked: 531 times
Hmm... is it automatic or manual?Ocelot wrote: 22 Dec 2018, 06:10 Hey guys,
- Ocelot
It's a manual transmission. Funny thing is, this started today. Yesterday and the days before, there were no hiccups at all.
Sidenote: a cold engine doesn't hiccup, so my theory is it only hiccups with a warm engine.
Recent car
Recent car
I was going to suggest the clutch switch, but that would likely affect the car at all times. Also, I don't think the clutch switch in these cars affects the engine, it's just there for cancelling cruise control.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
When I had hiccups as you described, new plugs, cap, rotor, wires, fuel filter, and finally a new fuel pump relay fixed it. Would start with testing the relay, especially if it's aftermarket.
Knows enough to be dangerous
- Ocelot
Thanks for the advice! I will look into buying new plugs, wires, a rotor and cap since I can't find in the maintenance history when they were last replaced. Should I buy OEM parts in this particular question or is aftermarket also okay? (except the fuel pump repay, I heard ya about that one)
Recent car
Recent car
- Been thanked: 4068 times
OEM parts for everything if you want to run the car long term. Spark plugs are important too, especially in turbo models. We have had a couple of stutter threads resolved by switching to Volvo plugs
Moved from chat, created new thread, retooled
- Ocelot
Is there an easy way to check the fuel pump relay before buying a new one?WhatAmIDoing wrote: 22 Dec 2018, 21:22 When I had hiccups as you described, new plugs, cap, rotor, wires, fuel filter, and finally a new fuel pump relay fixed it. Would start with testing the relay, especially if it's aftermarket.
Recent car
Recent car
- Year and Model: Many Volvos
- Been thanked: 76 times
You can use a piece of wire to bypass it altogether. The wire goes between the socket positions associated with pins 15 and 87 that are marked on the relay.Ocelot wrote: 23 Dec 2018, 06:13Is there an easy way to check the fuel pump relay before buying a new one?
- 13 Replies
- 2927 Views
Last post by echase76
- 21 Replies
- 2770 Views
- 26 Replies
- 3873 Views
- 3867 Views
Last post by marmotteNZ
- 991 Views
Last post by luke lennard
