Just a small warning with the clogged sunroof drains. At 0:40 and 5:00 in this video I mention the side curtain airbag got wet from this this. It would be important to check these curtain airbags if the sunroof drains got clogged, because with cold weather the wet airbag will freeze up and may get damaged from the ice formation. I know mine was already replaced by Volvo in the past.
So perhaps have a look at 0:40 and 5:00 in this video
- Been thanked: 4068 times
Started an extensive troubleshooting process involving CANBUS programming to find out why my rear 12V socket isnt working. Any guidance appreciated
Preliminary diagnosis is third seat heater interference with CANBUS ground
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Bought it. '04 XC70 160 k miles, Ruby Red Metallic. Needs a couple things (driver side window is off track and probably needs new slider blocks) but not really much at all.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
zjevik
- Year and Model: S60 2006
I just finished PCV job in hope that it's going to help my rear main seal leak. Started with small overpressure in the crankcase but now I have a solid suction in all rpm.
The old bajo bolt on the engine side had some calcium deposits (or rust?) inside and the one way valve was missing. I HATE both bajo bots, it took me good hour to get both of them on.
- E Showell
Took window out of spare driver door I bagged at Harry's the other day to use in repairing the '04 XC. I noticed the slider blocks were shot, but probably useable (I opted against reusing and since all dealer parts departments were closed today, ordered new replacements). If regulator in the car is OK, I'll have an easy repair and should be back in business by the end of the weekend.
'95 855 auto (sold)
'95 855 auto (sold)
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Replaced the light stalk mechanism. Old one was worn out with vague clicks. New stalk wrong colour and year so I had to take both apart and use just the mechanism from the replacement.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Hoppy Neu Yar (?) to all of you and yours!
(The google tells me it's actually "gott nytt år")
- Rattnalle
Yup. But a hoppy new year will do as wellBlackBart wrote: 02 Jan 2019, 12:36 Hoppy Neu Yar (?) to all of you and yours!
