oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Re: What did you do to your P2 Volvo today....now sticky!!
Post by oragex »
Just a small warning with the clogged sunroof drains. At 0:40 and 5:00 in this video I mention the side curtain airbag got wet from this this. It would be important to check these curtain airbags if the sunroof drains got clogged, because with cold weather the wet airbag will freeze up and may get damaged from the ice formation. I know mine was already replaced by Volvo in the past.
So perhaps have a look at 0:40 and 5:00 in this video
Has thanked: 1497 times
Been thanked: 3810 times
Started an extensive troubleshooting process involving CANBUS programming to find out why my rear 12V socket isnt working. Any guidance appreciated
Preliminary diagnosis is third seat heater interference with CANBUS ground
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
abscate wrote: 26 Dec 2018, 08:30 ... troubleshooting process involving CANBUS programming
Didn’t they use that on Apollo 8...?
ovlov9691
Year and Model: 1996 850r
Post by ovlov9691 »
Took my Sons car to the repair shop he Told me that the Gearbox is toast!! Not too good!
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
Bought it. '04 XC70 160 k miles, Ruby Red Metallic. Needs a couple things (driver side window is off track and probably needs new slider blocks) but not really much at all.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
zjevik
Year and Model: S60 2006
Post by zjevik »
I just finished PCV job in hope that it's going to help my rear main seal leak. Started with small overpressure in the crankcase but now I have a solid suction in all rpm.
The old bajo bolt on the engine side had some calcium deposits (or rust?) inside and the one way valve was missing. I HATE both bajo bots, it took me good hour to get both of them on.
E Showell
Post by E Showell »
Took window out of spare driver door I bagged at Harry's the other day to use in repairing the '04 XC. I noticed the slider blocks were shot, but probably useable (I opted against reusing and since all dealer parts departments were closed today, ordered new replacements). If regulator in the car is OK, I'll have an easy repair and should be back in business by the end of the weekend.
'95 855 auto (sold)
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Replaced the light stalk mechanism. Old one was worn out with vague clicks. New stalk wrong colour and year so I had to take both apart and use just the mechanism from the replacement.
BlackBart
Post by BlackBart »
Hoppy Neu Yar (?) to all of you and yours!
(The google tells me it's actually "gott nytt år")
Rattnalle
Post by Rattnalle »
BlackBart wrote: 02 Jan 2019, 12:36 Hoppy Neu Yar (?) to all of you and yours!
Yup. But a hoppy new year will do as well :-)
