Voltage for fuel injectors
shegarty
Year and Model: 1998
Has thanked: 12 times
Been thanked: 8 times
Post by shegarty »
Hi all, I have managed to source a set of used fuel injectors for my 98 S70 (Bosch 0280155766). I want to do a full clean and backflush on the bench before attempting to install them as I have no idea what kind of condition they are in. Do these run at a full 12V in the vehicle or is it a stepped down voltage? The last thing I want to do is fry a solenoid :roll:
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
12v ,battery voltage...or 14.4v(while engine is running).
You can't run them constantly with power source of 12v...you will need the switch for opening and closing them...to imitate ecu controller(about 2 times/second).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
shegarty
Post by shegarty »
Thanks for the info. I plan to just use an old battery on the bench and pulse it by hand, from what I have seen on the interwebs this should be fine for very short periods.
misha
Post by misha »
Just keep the battery and pulsing away from fuel and vapors...long wires would be a MUST...and well ventilated area.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
