Has thanked: 1500 times
Been thanked: 3810 times
Re: What did you do to your P2 Volvo today....now sticky!!
abscate wrote: 25 Nov 2018, 09:32 7500 mile oil change on the 2005, now at 120,000 miles
Mobil 1 synthetic.
Sending a sample to Blackstone for analysis.
Blackstone tells me the oil is doing well at 7500 miles
TBN 2.8 (>1.0 is spec)
Fuel <0.5% (2%spec)
Coolant 0%
Viscosity right in middle of range
All metals well below contamination spec
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Fixed w/s wiper motor on sis' XC90. Is that nut on the output shaft of the wiper motor known for coming loose? I used a new nut + epoxy between the shaft and the arm + impact hammer + loctite on the nut. It shouldn't ever come loose again on her. Fortunately the wipers didn't fail while she was driving.. in the driveway before she pulled out. I cleaned and put fresh synth grease in the arm pivots bearings while I had the whole thing off the car. The wipers run noticeably faster now, like they do on my S60.
erikv11 wrote: 25 Nov 2018, 11:45 6 fresh quarts of Mobil 1 0w-40 into the 06 R last night. So that's an 8600 mile OCI, now at 150,000 on the odometer. Mann filter.
Not sending a sample to Blackstone, I'll use abscate's data.
Data is up thread !! 10,000 mile OCI easily supported on my NA 2005
Link to report in my MVS Maintenance Log
viewtopic.php?f=35&t=66809&p=489699#p489699
Thought bubble - if I were buying a car and someone had a couple of oil changes of Blackstone data, I would feel pretty good about the engine condition in terms of blow by and metal wear. I don't see many doing this or at least advertising it.
Insert <stdio.h.disclosures/client== "Blackstone Labs" \\ #Nofinancialinterest == TRUE >
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Did a small video with the Aisin dipstick location for the new Volvo S60 owners
oragex
Post by oragex »
Found a trunk net at the breakers, not sure if this could be some optional genuine equipment ? Seems quite good quality
www.youtube.com/watch?v=-w3xX80s23Y
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
oragex wrote: 04 Jan 2019, 15:11 Found a trunk net at the breakers, not sure if this could be some optional genuine equipment ? Seems quite good quality
I'm pretty sure my S80 had one of those. Might have been part of the package with the shopping bag holder on the right side.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
Replaced driver side window on new-to-me XC70. One of the blue plastic nylon sliding blocks was completely gone, thus window stuck half open. Window jammed and broke. Used Harry's replacement. About 40 min. start to finish. Wife helped with extracting replacement and son held window in place, so a true family affair.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Picked up a new project V70 with blown engine, test drove a nice V70 NA stick.
Totally awesome ride with my helper on a 6 hour round trip pickup ride
E Showell
Post by E Showell »
I think you meant S70 project, unless it morphed into a wagon on the trailer. :D
'95 855 auto (sold)
It's a difficult transition to make. Nice seeing you again and will keep in touch of course.
Will lett you know about silver prospect.
