2001 V70XC - Chasing fluid at the bottom of the turbo Topic is solved
- Has thanked: 311 times
- Been thanked: 817 times
This thread is a really great resource. Thanks xHeart!
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
Don't buy these injector kits made by UREMCO (United Remanufacturing Comapnay) from EBAY nor Amazon. The pintle caps are twice as thick as the thin OEM caps so will no doubt cause a lean A/F mixture.XC70Rider wrote: 24 Dec 2018, 08:33 If you haven't replaced the injectors O-rings then be very careful removing the old ones. The pintle caps are very brittle on these old injectors. One pintle cap partially broke off. It still surrounds the injector cap 100% so it should hold the new O-ring in place until I get this injector repair kit delivered
https://www.ebay.com/itm/FUEL-INJECTOR- ... 2749.l2649
The replacement caps on ndphotonl's injectors appear to be as thin as OEM so I'll give them a shot when they arrive from AliExpress then report back.
https://www.aliexpress.com/item/Free-sh ... 58425.html
XC70Rider
Thank for the tips Xheart!
After I repair my injectors I'll drop the pan, install new timing belt, and water pump.
Did you drain the coolant to remove the oil cooler or just pinch off the hoses?
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Thank you for this update.XC70Rider wrote: 06 Jan 2019, 13:09
Volvo coolant was more than 3 years old, and this was good maintenance to include a coolant refresh -- breather kit's other bonjo bolt is a coolant line. The original Volvo radiator had worked long enough -- 190,000 miles -- retired due to signs of leak at the hose connection to thermostat.XC70Rider wrote: 06 Jan 2019, 13:13
- ndphotonl
- Year and Model: 2001 S80 2.4T
- Has thanked: 27 times
- Been thanked: 33 times
I haven't had an issue since after servicing the injectors with that kit. I checked my AF ratio, with normal driving/coasting its always around 1:14.7.XC70Rider wrote: 06 Jan 2019, 13:09Don't buy these injector kits made by UREMCO (United Remanufacturing Comapnay) from EBAY nor Amazon. The pintle caps are twice as thick as the thin OEM caps so will no doubt cause a lean A/F mixture.XC70Rider wrote: 24 Dec 2018, 08:33 If you haven't replaced the injectors O-rings then be very careful removing the old ones. The pintle caps are very brittle on these old injectors. One pintle cap partially broke off. It still surrounds the injector cap 100% so it should hold the new O-ring in place until I get this injector repair kit delivered
I have only 1 recurring error after fitting the BSR 3" downpipe with sportcat, but that is due to the second lambda (I have a spacer waiting to be fitted).
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
xHeart
What is AFR parameter in ECM over VIDA/DiCE? Does it read 1.00?ndphotonl wrote: 07 Jan 2019, 11:04
- ndphotonl
I checked using Torque (Android app)
[edit]
Matt, if you are reading this, I cant reply with a PM.
[edit]
FlickR images
FlickR images
xHeart
Learned about Using Freeze Frames for fault tracing.
I'm good for now.
Thank you!
I'm good for now.
Thank you!
xHeart
Dry as bone - no longer a blow-by. PCV and oil pan clean up did the job. Running above 17mpg.
- 21 Replies
- 9100 Views
Last post by - Pete -
- 13 Replies
- 5450 Views
Last post by oragex
- 21873 Views
- 1230 Views
Last post by shegarty
- 17 Replies
- 11591 Views
Last post by JohnnyBee323
