Car dies while driving
940tvolvo
Year and Model: 1991 Volvo 940turbo
Post by 940tvolvo »
Merry Christmas -- I have a 1991 940 T Volvo that just died while I was driving. AAA came to give me a jump, but it wouldn't take a jump ended up having to tow it home. Cars turns over, just won't start.
Any thoughts would be greatly appreciated??
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Give it a 3 second shot of starting fluid, see if will fire.
Active
Past
940tvolvo
Post by 940tvolvo »
Okay thank you I will give that a shot. Question though, could it be my timing belt? I have never had a timing belt go out on me so I have no idea of what it would do if the timing belt went.
940tvolvo
Post by 940tvolvo »
Is there anyone in Portland, Oregon who would be willing to give this single women a helping hand look at my car. I have no money to offer, but i do have cords of wood. I am at a loss and really need my car up and running. Thank you
RickHaleParker
It could be a slipped timing belt. Take the plastic cover off the top of the engine and press down on the timing belt. If it is loose it could be a slipped timing belt.
Do you know how many miles have passed since the last time the timing belt was replaced. Your suppose to replace timing belts at regular intervals ... one should never wait until a timing belt goes bad.
Active
Past
940tvolvo
Post by 940tvolvo »
I do not know when it was replaced last. The odometer has been broke since I've owned the car which is 4 years. So it has been at least 4 years. The car turns over just seems like there is no spark.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
940tvolvo wrote: 29 Dec 2018, 21:42 I do not know when it was replaced last. The odometer has been broke since I've owned the car which is 4 years. So it has been at least 4 years. The car turns over just seems like there is no spark.
If the timing belt has broken the engine will turn over like it has no compression. Once someone has had this happen they know what it is next time it happens.
1988 Volvo 760 Turbo Wagon
940tvolvo
Post by 940tvolvo »
So my roommate took one of my spark plugs out and touch it to something to see if it was getting a spark and had me turn the car over, he said it was getting a spark, so the timing belt was good. I check fuse 1 and 11 they are good. ???
RickHaleParker
You can still get spark with a slipped timing belt. Note: I said slipped, not broken.
Active
Past
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
RickHaleParker wrote: 06 Jan 2019, 00:44You can still get spark with a slipped timing belt. Note: I said slipped, not broken.
You can also get spark with a busted dowel-pin on cam sprocket....which is not the same as a slipped timing belt. Volvo's B23F engine has this issue...I know, first hand.
