Oh, just a regular day in the neighborhood when all of a sudden, your exhaust starts to growl.
Might be time to cut this out and weld something in...
Can this be welded?
Will head over to Willets Point and see what they say.
More exhaust woes: Break right after catalytic converter
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Retired:
2015 Volvo S60, T5, 85K
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
It is pretty rusted/rotten for the weld to stick, plus it will need to come out to weld all around. If it's a non turbo it may be easier to undo at the manifold, but the bolts will be rusted solid too so perhaps they will put the torch on them. If you take it out and they try cleaning the opening to put the welder on it, make sure they weld the two parts properly aligned, or it will cause other problems and perhaps crack the flexible downpipe not long after. It will take a skilled guy to do a good job
An aftermarket flex pipe with cat runs for $2-$300 on Ebay but fitting can be troublesome and you may get poor emissions
- Been thanked: 4069 times
Yeah, that’s not weldable. Welding will just blow the metal away. Aftermarket lasts 2-3 years or bite the bullet and get one from FCP for life.
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
I've had 3 with that problem. Midas stuck a 6 inch piece of new pipe into the back of the cat and welded it in to the rest of the existing exhaust. Never heard back from any of them. Won't say what it cost because my buddy owns the shop but even at retail I think it's a $50 fix tops. They removed nothing but the crossmember and I was out of there in an hour in all 3 cases. One thing I just won't do myself is exhaust. Those guys weld WAAAY better than I do.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- 4942 Views
Last post by MadeInJapan
- 2811 Views
Last post by mkc1
- 746 Views
- 12 Replies
- 2743 Views
Last post by FireFox31
- 709 Views
