I purchased my 2009 XC90 in November, it had sat on the lot for a few months. No issues whatsoever with starting. I replaced the battery knowing it was an older batter in early December. Roughly a week and a half ago my wife drove the vehicle to a farm and did chores, when she prepared to head home the car started but had no radio, no lights, no heat, no turn signals, no wipers, it was not a rough start. I read other forums that referenced the ignition switch as this cause.
I purchased a new Volvo ignition switch from FCP Euro and installed it tonight however no changes to my situation. When I open a door, the car beeps like a key is in the ignition. When I place the key in and move to sector l the radio turns on, the wipers and turn signals work. When I move the key to sector ll the radio turns off and will not turn on and near the end of sector ll before turning the car over the car starts while still in ll without ever having had cranked it over in lll. I am assuming it is maybe a bad spring where the key turns? There is a remote starter attached, and I'm not sure if I should take these wires off to have a look. I have tried to troubleshoot and read up on other parts, could the Volvo Ignition Immobilizer be bad and affecting this or could it be a bad tumbler?? Any suggestions? We can drive it in an emergency but it is not ideal. Thanks for thoughts..
Xc90 Starting Issue
Cluelesslyhelpless
- Year and Model: 2009 Xc90
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Not sure it's an immobilizer problem acting this weird. Maybe a barrel problem ? Does the alternator pump a decent 13.8-14.5V ?
- 876 Views
Last post by Roger_850T
- 619 Views
Last post by 01_Nautic_V70
- 1142 Views
Last post by xlewis0
- 786 Views
Last post by brando_calrissian
- 11 Replies
- 2653 Views
Last post by precopster
