donoscituate
- Year and Model: v70 1999, 2005 v70
All my windows stopped working, also the electric mirrors would not adjust, and finally the electric sunroof wouldn't work. This is a 99 V70, so I spent a bit of time looking on the forum, and with that info, went to the junk yard, and found another master window switch for $10, popped it in and magic, everything works again. Another thank you to the forum.
- Has thanked: 1614 times
- Been thanked: 4078 times
Nice, what junk yard did you hit? I need some 99 body parts...do you remember any colors?
Well in all this excitement I can't remember if I fired 5 or 6 cylinders...abscate wrote: 09 Jan 2019, 19:25Quick update. Houston, we have rotation. Cylinder 5 has freed up. I hope to see if I have a runner by end of weekend. They make these engines tough.abscate wrote: 09 Jan 2019, 14:05Sneaked out into the garage over lunch and the potion has dropped! I will try spinning the crank pulley tonight. Have to work in NYC tomorrow, if I am lucky I will take Friday and see if I have a runner!!!abscate wrote: 07 Jan 2019, 11:44 Got Evita the new V70 S70 into the garage and evaluated seized engine. Started a maintenance thread to record for now. If I make good progress, Ill create a 'how to recover a seized engine thread"
Irish bookmaking odds are now up to 50-50 on Lady Evita Recovery
From my maintenance log (Optimist)
Evaluation of motor this weekend.
Got 30mm socket on crank pulley - I can feel crank turning and resistance in pistons. I removed starter and confirmed that the flywheel is moving slightly, but then I put Pooh sticks into all cylinders, 1-4 move but number 5 is stuck firm.
Gentle pressure on pistons confirms movement in 1-4, none in 5
Borescope in 5 unremarkable.
Ive got a feel I have stuck ring in the bore.
Added MMO/diesel/acetone in a proprietary mixture, known only to MVS, to Cylinder 5.
Planned strategy - give it a week soak, then see if I can break it free and retain compression.
A well working MM ETM body will be sacrificed to Odin, God of Volvo this week for compensation.
Sneaked into the garage. Pulled plugs, hooked up battery, engine is spinning nicely, sounds good. Getting 150 psi on 5
Put new plugs in , will fire up in morning.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Sounds like you might have a winner abscate.
Busy day today. Oil change, new license plate lights, and cleaned up the mess from when the axle boot clamp fell off and added some more grease. Also spent some more time diagnosing the short in my fog lights.
Knows enough to be dangerous
Started at 0 dark 500. Cup of coffee. Have had battery on charger then trickle for a week.
First problem, key not releasing from ignition. Oh well, doesn't need to be addressed today. Robert has a fix I'm sure.
No crank condition. Applied voltage to remote crank position, no joy. No solenoid click, not significant current pull. Bad solenoid/ starter? Swapped in spare. Deep breath. Turned key.......
Vroom! We have a runner!!
Lots of valve ticking. Lady Evita promptly signals her displeasure at being awakened by dumping engine oil, looks like chocolate milk
Sad trombone....but I'm hopeful it's just sitting condensation. Coolant clear as new, spun off oil filter, cartridge type, has rusted out. Parts store open in an hour, will grab a new one and use up some of that used synthetic from Scots Used Lube in Calgary to flush..
Stay tuned...
Stay tuned...
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
This is a bit like mission control waiting for the latest reports from the moon.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Not sure about this. I reuse old oil all the time, but only as chain oil in my JonseredRattnalle wrote: 11 Jan 2019, 04:03 It really hurts to say this but I might actually agree that using used oil isn't a bad idea here to flush out the chocolate![]()
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Has thanked: 317 times
- Been thanked: 531 times
Haha, right?E Showell wrote: 11 Jan 2019, 04:22 This is a bit like mission control waiting for the latest reports from the moon.
New oil filter, drained old, flushed with used, New Mobil 1 SYNabscate wrote: 11 Jan 2019, 04:00 Started at 0 dark 500. Cup of coffee. Have had battery on charger then trickle for a week.
Stay tuned...
Ran it around block, smooth as silk
No codes, AT shifts smoothly
"Gentlemen, its been an honour flying with you...."
Sidebar - has anyone ever Slo-Mod there timing belt for diagnostics? Ill figure out how to post movie.
