Cold start issues.
pb49415
- Year and Model: 1998 S70
My 1998 S70 is having cold starting issues. Since winter began. Once again I’m having startup problems. When I initially crank it over it fires up and then stalls. Takes about 5 minutes of sitting and sometimes leaving the ignition on before it will fire and stay running. During the warmer months it behaves normal. It’s only during cold winter days/nights when it’s parked for a few hours outside. Typically below 25degs F. Looking for some information on what might be going on?
- Year and Model: Many Volvos
- Been thanked: 76 times
How does the temp gauge behave? Does it go to the 3:00 position and stay there?
A bad ECT sensor can cause your problem but so can a weak fuel pump.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
...or fuel pump relay.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
The ECT measures the coolant temperature. It is located near the thermostat. If it is reading out of spec, you will get starting issues. The fuel pump relay is also easy to test. Can you hear the fuel pump prime when you turn the key to POS II?
Knows enough to be dangerous
dj_v70
- Year and Model: v70 2003
- Has thanked: 7 times
- Been thanked: 23 times
It sounds like engine is flooding for some reason. Do you smell gas at exhaust pipe after it stalls? After it stalls, press gas pedal to floor and hold it there to see if you can start it by cranking for 10 seconds or so (if it is on the verge of starting, keep cranking until engine starts to rev up and hold rpms at 2k until runs smoothly). If so, engine is getting flooded. That would narrow it down a bit.pb49415 wrote: 10 Jan 2019, 02:39 When I initially crank it over it fires up and then stalls. Takes about 5 minutes of sitting and sometimes leaving the ignition on before it will fire and stay running.
pb49415
That’s what my original thoughts were too. But, the only difference is that if I leave the ignition on for a full minute before starting, I’ll fire and stay running. It would seem to me that if it were flooded it would have more trouble. Anything let’s say above 30 degrees it’ll start and run fine. It’s only if it sits out overnight while I’m in the shop working.
dj_v70
Just to be clear, are you saying that the car starts/runs fine when its cold as long as you let the ignition stay in pos 2 for a full minute without starting? If that is the case, sounds like fuel pressure is having hard time getting up to full pressure. I have read on these forums that some have used cheap tire pressure gauges to check fuel pressure on fuel rail. I'd give that a try while a helper cranks the car.
- 3112 Views
Last post by nucci480
- 589 Views
Last post by WhatAmIDoing
- 1868 Views
Last post by matomorizo
- 1296 Views
Last post by maverill
- 853 Views
Last post by erikv11
