Hi
Have a C70 2000
When I put my scanner in the OBD then the power light is on, but not the other two lamps.
They come on as I connect it, but goes out again.
Same with the Volvo Vida. No connection.
Has worked before.
Tried to change the wire in the tunnelbox. Did not help.
Could it be a groundcable ?
OBD no signal
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Would suggest checking the 12V+ and grounds that go to the OBDII connector. It is also possible one or more terminals within the connector have some corrosion built up.
2023 Lexus RZ450e -66k
- wizechatmgr
Next idea I would have would be to unhook the battery and reseat the ECU.
- wizechatmgr
Yes, but I'm not sure most scanners other than VIDA will be able to see it. Ignition switch is in position II when you're attempting to communicate with the vehicle, correct?jantt wrote: 13 Jan 2019, 21:48 Sometimes my abs + stc lampes goes on.
Think I have read that faul on abs unit can have somrthing to do with obd. Is that right ?
- wizechatmgr
Any chance you can take pictures of these? I appear to be daft tonight =)
- 3307 Views
Last post by Sommerfeldt
- 8926 Views
Last post by rhubarb
- 1163 Views
Last post by 93Regina
- 1223 Views
Last post by whtwgn
- 2879 Views
Last post by precopster
