Hello,
Can anyone tell me where I can find the Engine ID Label on my 2015 XC60 T5? The engine is, according to information I received with the car, a 2.0 4 cyl. T11, but I would like to confirm it. Any help will be appreciated.
Locating Engine ID Label on 2015 XC60
- RickHaleParker
- Been thanked: 958 times
gutebo
- Year and Model: 2015 XC60
- Has thanked: 2 times
Thanks Jim and Rick,
I did find the Engine Label on the timing belt cover. See Eng Lbl-1 and Eng Lbl-2.
The Engine Label reads as follows:
Part No. (P) 36010160
Serial No. (1) 2634259
According to the Owner's Manual, Volvo offered four different 4-cylinder engines for the 2015 XC60.
The engine designations were: B4204T9, B4204T10, B420411 and B404T12.
With the help of the Parts and Serial numbers, can anyone tell me if I have a T9, T10, T11 or T12 engine?
- RickHaleParker
It looks like Part No. 36010160 = B4204T11 BUT it is not clear if 36010160 is a engine exchange number or specifically the B4204T11 build.
Run your VIN number thru the Volvo Tech VIN Decoder, it should list what engine was installed.
- RickHaleParker
Googled "Volvo 36010160" then went through the links see what it leads to. As I indicated above I never got a definite description.
- regent
- Year and Model: 2015 XC60 T5
- Been thanked: 12 times
Not sure if this was solved; I just happen to have a 2015 XC60T5 with the T11...
You can look up the engines here:
https://parts.volvocarslisle.com/p/Volv ... 10160.html
and then narrow down by your Chassis Number. Hope this helps.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
