This is an awesome tip for under dash work of significant time3. Someone mentioned making a platform to make it easier to work under the dash. I put a board on top of 2 five-gallon buckets, and a pad on top of that, and it made it a lot easier than when half of me is hanging out of the car into space.
Narrow Down Low Cabin Heat Issue Topic is solved
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Someone left a comment on the heater core video, he said a trick so he didn't had to bent the metal tubes
- at the rubber heater hoses inside the engine bay, remove the quick disconnect and the mounting plate
- blow into a hole (use a small hose): this will empty a little the heater core so it won't leak when removed
- from inside the car, cut the tie wrap that binds both tubes at the top: once disconnected from the heater core, the metal tubes will move away easily - no longer needed to bend them to get them out of the way
- 14 Replies
- 3615 Views
Last post by Rattnalle
- 733 Views
Last post by Kach
- 581 Views
Last post by MarcM
- 26 Replies
- 5482 Views
Last post by dejanaleksov
- 26 Replies
- 4220 Views
