Ok, so I just recently got a 1999 Volvo S70 base model, and it's got a weird issue going on- it doesn't crank, but when it's jumped it'll occasionally just start right up and drive and all.
Looking through the possible issues haven't really helped, I haven't seen anyone else have this particular problem.
My guess is that the ignition switch has broken, do you guys think the same?
My reasoning is that since it starts occasionally, then the car has to think that the key is turned all the way to the III position.
1999 S70 Weird starting issue [Ignition switch electrical shorted to START] Topic is solved
melmaclifeform
- Year and Model: 2000 S70 GLT SE
- Has thanked: 2 times
- Been thanked: 7 times
2000 S70 GLT SE
1997 Volvo 850 T5
2011 Volkswagen Jetta SE
1999 Mazda Miata
1997 Volvo 850 T5
1999 Mazda Miata
- RickHaleParker
- Been thanked: 979 times
Could be the Antenna ring on the fritz. The key has a RFID chip in it. The Antenna ring (the RFID reader) is that plastic ring around the key hole. It is common problem.
Active
Past
Past
melmaclifeform
Hmmm, is that an easy repair? The thing that made me think it was the switch was that the key turned without any resistance, really. It wasn't like that in any of the other cars that I've driven so that might be of more assistance.
2000 S70 GLT SE
1997 Volvo 850 T5
1999 Mazda Miata
1997 Volvo 850 T5
1999 Mazda Miata
- RickHaleParker
It is very easy and on a '99 no reprogramming required.
[youtube][/youtube]
[youtube][/youtube]
Active
Past
Past
melmaclifeform
Awesome! Thanks man, I'll try that first
2000 S70 GLT SE
1997 Volvo 850 T5
1999 Mazda Miata
1997 Volvo 850 T5
1999 Mazda Miata
An antenna ring problem will leave you with a crank,no-start problem, not a no crank problem
How old is your battery and what is state of charge?
Turn headlights on for 30 seconds, turn off, then measure voltage and temperature at battery
Electrical part of ignition switch would be my first stop if you want to try parts swapping approach.
- Has thanked: 311 times
- Been thanked: 817 times
Agreed, it's not the antenna ring.
Obvious candidates, in order of likelihood:
(1) Electrical portion of the ignition switch
(2) Positive or B+ battery cable
(3) Battery
Since you can test the battery and the cable. All as abscate suggested.
(3) Battery
melmaclifeform
The car is charged enough to turn EVERYTHING on as soon as the cables are connected. Wipers will go on and whatnot, all of that stuff.
I know the battery is a few years old old, but it's been tested and it is a good battery that holds a charge.
2000 S70 GLT SE
1997 Volvo 850 T5
1999 Mazda Miata
1997 Volvo 850 T5
1999 Mazda Miata
- RickHaleParker
Take the battery to Autozone and get a free bench test. The battery may hold a charge but not perform under a heavy load. The starter is a very heavy load ....
Active
Past
Past
melmaclifeform
See, even if it was the battery I think there might be more problems, it starts WITHOUT turning the key when you jump it
2000 S70 GLT SE
1997 Volvo 850 T5
1999 Mazda Miata
1997 Volvo 850 T5
1999 Mazda Miata
- 1583 Views
Last post by JDS60R
- 1580 Views
Last post by paredown
- 1405 Views
Last post by MadeInJapan
- 872 Views
- 967 Views
