Hello,
Here my next post as I'm trying to get my car back in good condition.
I noticed an oil leak on the passenger side of the engine, near the time belt area, at the backside of the engine.
I took one part of the timing belt cover off and could see some traces of oil in that area, but I was not able find the oil leak just by a visual inspection.
The car has 160k+ miles on it and the timing belt has been replaced at 100k miles.
Here some pictures of the timing belt area, where it looks like the belt somehow picks up some oil:
2004 S80 2.9L NA - Oil leak
Hello,
What is on the passenger side at the back of the engine that may cause an oil leak?
All PCV hoses and stuff are at the front of the engine right?
1997 850 NA Wagon - 261,000 miles - Is no longer
2004 V70 NA Wagon - Saved my life
2004 S80
2004 S80
- bojified
- Year and Model: 2003 XC70, 2004 S80
- Been thanked: 2 times
Looks like a possible exhaust cam seal? Seems to be above where the waterpump housing is so could also be valve cover?
More pictures from above on the firewall side might be helpful.
2004 S80 Wife's daily driver. Still have, 2003 XC70 T Daily Driver. Still have, 1997 854 Kept going for daughter, 1992 944 - Diplomat Delivery, 1997 855, 1989 744 saved my life!, 1987 744 T, 1988 780 BERTONE, 1988 765 T, 1987 744 T, 1981 244 DSL, 1974 164, 1976 265 PVR, 1981 264 GLE, 1971 145 DL, 1976 245 DL
I want to check the PCV system too, make sure it is not clogged.
I used to have an 850 and a V70, and one of the checkpoint was to see if there is positive pressure coming out of the oil dipstick tube. (smoke or air coming out of the tube, instead of sucking air in)
Is that also the case with the S80's?
2004 S80
2004 S80
- 3993 Views
Last post by matthew1
- 791 Views
Last post by UgDriveCar
- 737 Views
Last post by Synergychaz
- 1541 Views
Last post by vtl
- 1411 Views
Last post by t3yf5g
