Low Beam Headlight bulb access?
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 158 times
Been thanked: 6 times
Post by Mr. Detail »
Darn it, I just went out in the driveway to replace both low beam H7 bulbs and I thought it would be easy. Instead I found a bunch of unknown wire harnesses tie-wrapped together right in front of my circular access door. Can away those tie-wraps so I can get some extra slack to even see the plug for replacement?
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
What are you working on?
Your sig says 2002 P2...
We need details, Mr!
Mr. Detail
Is a "P2" the same thing as a "V70"? I have a '02 Base V70 wagon.
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Then yes it's a P2. It's the platform name.
They're a pain to get to. Some people take the air filter housing and stuff out.. it's doable with everything in place but not easy.
I'm sure any cables that are fastened in the area used to be secured by clips that have broken and been replaced with zip ties. Just zip then back when you're done and you should be able to move them carefully.
BEJinFbk
Post by BEJinFbk »
I ask because this is the P80 area of MVS, only up to MY 2000.
The -‘01 and newer years are very different cars.
Mr. Detail
Thanks for asking "BEJinFbk" and thank you "Rattnalle" for your response.
BEJinFbk
Post by BEJinFbk »
If I knew squat about the newer cars, I’d be happy to throw in, but alas...
I’m trapped in 1998! And these heated seats are soooo comfortable. :)
Mr. Detail
Amen to those heated seats!
Rattnalle
Post by Rattnalle »
BEJinFbk wrote: 15 Jan 2019, 17:36 If I knew squat about the newer cars, I’d be happy to throw in, but alas...
The newer heated seats go up the back as well, I don't remember my P80s having heated seatbacks. :-)
BEJinFbk
Post by BEJinFbk »
Rattnalle wrote: 16 Jan 2019, 05:39
Oh, yeah....
It was -40 here last week.
Trust me - They do ! :mrgreen:
