96 850 Voltage regulator 9162683 1 197 311 520
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
PeteB wrote: 16 Jan 2019, 09:42 I don't see anyway to release the old brushes, it looks like the pigtail wire, if it has
one, is crimped in the back.
That is attached to a small solid wire that is soldered in place in the regulator. You drill out the old brushes (they disintegrate) and carefully drill out the solder joint. You then feed the new brushes in and solder the wire in place, trimming off any excess.
VIDEO
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Been thanked: 11 times
Post by PeteB »
Thanks very much Chuck!
Mine are crimped and not soldered and I thought about drilling them out
then soldering in the new ones so it seems that will work just fine.
That guy gave a link to his ebay store to buy the brushes but it is dead now,
seems partsgeek also sells them - will look for the correct ones.
Chuck W
Post by Chuck W »
I should have the part number at home. I bought an extra set or two, so I know they're on the bench.
Chuck W
Post by Chuck W »
Sorry. Posted the PN in the wrong post.
The Bosch PN for the brush set is 1 127 014 028.
Kanabea
Year and Model: 1996 850 Turbo
Post by Kanabea »
I found the BOSCH 1 197 311 520 for $25 at an Electric supply company in Dallas, TX
https://www.maniacelectricmotors.com/80 ... 1592850870
Been thanked: 4065 times
Kanabea wrote: 22 Jun 2020, 13:05 I found the BOSCH 1 197 311 520 for $25 at an Electric supply company in Dallas, TX
I just looked this over and am not convinced its Bosch. Reading the lines and looking at the picture, it looks like a knock-off
Update - Ive ordered one since all the brands are now outsourced remanfuacturered in various overseas countries
Will update my experience here.
Popped the 1998 alternator out and removed regulator
Note corrosion on the contacts and that the brushes are not equally worn. One either got stuck or ran out of spring
New ones have more thantwice this length
By the way, from the P2 forum
Replace the voltage regulator or alternator with a low mile used OEM one;
I made the mistake of putting a Duralast alternator in my car 4 years ago. I couldn't have any downtime and the cars in the yard had 300k+ on them. I've since used the lifetime warranty on it 4 times...
Junk.
Has thanked: 311 times
Been thanked: 817 times
Yes. Just say no to aftermarket regulators if you can. Rebuilding with new brushes seems one good way to go.
The aftermarket VR in my T5-R is still working, although that car does not get a lot of miles maybe 3k per year.
Helchemist
Year and Model: 1996 850R
Post by Helchemist »
Great thread and very timely!
Having issues with power on my 98 V70R and the AutoZone tester revealed alternator as the cause. Primed with a previously ordered part from FCP, I pulled my VR today only to find my old one has the LRC and the new one doesn't. Is it possible to use the small VR on a LRC type? Can you leave it unconnected?
1996 850R (iPd HDTCV, RIP, turboback exhaust, strut tower brace) [160k]
1999 S80 [200k]
1995 850 GLT NA 5spd [300k]
1988 740 GL
1984 240 DL
