2004 S60 Power Steering Leak
StickyPocket
Year and Model: 2004 S60 2.5T AWD
Has thanked: 42 times
Been thanked: 6 times
Post by StickyPocket »
So today I went to start the car in ~12 degree Farenheit because I haven't driven it in a while. On startup, I get an error message saying "coolant low, stop engine". I turned off the car, waited a minute and restarted it, and that message was gone for several minutes of idling. I opened the hood to check the coolant (it was a little low, will be adding coolant), and noticed that the area around the power steering reservoir was wet. Picture attached. Unsure how long the leak has been happening, but it looks like the pipe underneath is wet as well. What could be the issue here? Some kind of gasket failure?
2004 S60 2.5T AWD
Been thanked: 472 times
Post by cn90 »
- The hose below looks new (there is a Blue Label on it).
- Get a new reservoir from dealer for about $50-$60.
- Search forum for Dexron vs Pentosin.
- You probably have over 180K (what is your mileage)...
- At this mileage when the PS reservoir is bad, may not be a bad idea to replace the coolant reservoir + cap too. Use only Volvo OEM reservoir.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
cn90 wrote: 21 Jan 2019, 17:45 - The hose below looks new (there is a Blue Label on it).
+1 June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
StickyPocket
I'm only at about 63k... hard to believe i know - it was a family car that didn't get much use. Was dealer maintained for much of it as well.
2004 S60 2.5T AWD
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
From experience, the PS reservoirs leak at the middle seam. Don't bother trying to separate the coolant tank from the PS reservoir. There's a plastic tab holding it to the coolant tank. It doesn't release easily. Just cut it off. Also, when you lift the coolant tank, don't lift it high. The level sensor wires are fragile and short (not a lot of slack). You'll break the sensor. Plastic and age, not a great combo for the PS reservoir or coolant expansion tank.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Post by cn90 »
At this age (15y and 63K), there is a round hose behind the engine block.
This hose can leak very slowly.
Not a bad idea to replace that short hose, about $8 from Volvo dealer.
StickyPocket
cn90 wrote: 21 Jan 2019, 18:37 At this age (15y and 63K), there is a round hose behind the engine block.
So from the above conversation, I'm planning on replacing the PS reservoir - it looks like that's definitely the problem according the picture, right?
Which round short hose are you talking about - would you happen to have a link to the part? Is this also easy to replace? How much do you think the labor for the reservoir and short round hose behind the engine block would be?
2004 S60 2.5T AWD
E Showell
Post by E Showell »
Don't pay someone to change the ps reservoir. Easy DIY but for the plastic tab holding it to the coolant overflow tank.
'95 855 auto (sold)
StickyPocket
E Showell wrote: 21 Jan 2019, 19:00 Don't pay someone to change the ps reservoir. Easy DIY but for the plastic tab holding it to the coolant overflow tank.
I would do it myself, but live in a city and park my car on the street. I don't have tools such as hose clamps and such. Also it is very cold outside...
2004 S60 2.5T AWD
June
Post by June »
StickyPocket wrote: 21 Jan 2019, 18:42
Yes, here's a picture of mine on my 2004 before replacing. Since new reservoir installed no leaks, stays perfectly dry. No hoses were replaced on my car. June
My Volvo cars owned
1996 960 ordered
