2006 Volvo S60 2.5 AWD, Endless search of problem
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Try unplugging injectors one at a time. The one that causes the least disturbance to the idle is usually the bad one though there are no hard and fast rules here because pulling an injector connector also causes bad idle.
I was called out to a 2001XC70 that the roadside mechanic had diagnosed as a faulty throttle; it needed a coil pack. Apparently he had a Snap-On scanner.
Most scanners can't pick up all the sensors accurately. In this case I feel it's time to pull out the big guns.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Missing pintle caps can result in residue build up on the injector tip, poor fuel spray, lean mixtures, poor driveability and high emissions. If it ran good immediately after servicing the injectors and then degraded over time that's probably it.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
Unownreality wrote: 21 Jan 2019, 22:43 To answer a few of the posts.
- New plugs, and coils this past summer. Did the whole tune up of the car
- The injectors, you may be onto something here. When i removed the fuel rail, all of the caps where deteriorated, and I couldn't find replacement caps. So the only thing in them right now is the o-rings that were replaced. I can't seem to find just the plastic washer caps. Napa and Autozone had no idea, and just tried pushing new injectors at $80x5. Figured as long as the o-rings sealed, should be good.
- I cleaned the MAF with a cleaner, and wire brush. Tested using the computer, and the throttle opens and closes as necessary.
Also, after resetting the computer post O2 change, no more P0101. Now just the P0170 code.
Do you install new injectors or re-install the old ones with new O-rings and missing pintle caps? Don't risk driving it without pintle caps. The O-rings will get sucked into the chamber over time without caps.
This kit has the same size pintle caps as our OEM injectors
https://www.aliexpress.com/item/Free-sh ... 58425.html
It's located in China so will take 2 weeks to deliver in the states. Under microscope they were the same size caps as the OEMs. I installed them 2 weeks ago and the A/F ratio is on target with no issues. Another member installed them a few years back and has had no issues with them.
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 57 times
Been thanked: 39 times
Post by EngineeringBloke »
You mention using a wire brush on the MAF
- Did you just clean the MAP tube's plastic grid, and not touch the MAF sensor itself with the brush?
Usually no contact is needed - just use of the cleaner.
- Also did you use MAF cleaner or another product?
MAF cleaner evaporates without any deposit. Any deposits left on the sensor can affect the air flow and temperature measurements. Typically deposits reduce the air mass measure so understates the air mass and results in a more lean mix.
- A dirty MAF issue would show up more in the air to fuel ratio, rather than the throttle opening.
chrism
Year and Model: S80 / 2005
Been thanked: 89 times
Post by chrism »
XC70Rider wrote: 22 Jan 2019, 09:05
I don't see any pintle caps in that repair kit.
XC70Rider
Post by XC70Rider »
chrism wrote: 22 Jan 2019, 09:49
There are 50 white pintle caps in the kit. Read the entire webpage.
Unownreality
Year and Model: 2006 S60 2.5 AWD
Post by Unownreality »
The injectors all looked good, and I haven't had any problems with them on the scan tool. I looked at my data and it seems to be running rich all across the board. I'll buy these pintle caps and hopefully that will solve the problem. It's hard to tell if they degraded overtime since I reinstalled them. We used a cleaner while looking at the valves, so when we initially started it the cleaner was running through so I wasn't running perfect.
XC70Rider
Post by XC70Rider »
If you need them sooner I can mail you 10 pintle caps with 10 lower O-rings. When you get your kit delivered you can mail me back the same amount.
Send me a PM with your address in RI and I can drop them off at the PO today.
Use payapl to purchase the kit and you'll get a $10 discount.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Unownreality wrote: 21 Jan 2019, 22:43 just tried pushing new injectors at $80x5. Figured as long as the o-rings sealed, should be good.
These ones? https://www.fcpeuro.com/products/volvo- ... 31#fitment
Not sure if you have the same MAF, mine looked like this www.youtube.com/watch?v=-bejldUOfVs
Unownreality
Yes those are that are in my volvo. Even at $45 a pop, dont want to change whats not broken.
