How to make my V70 XC powerful?
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Rattnalle wrote: 23 Jan 2019, 13:46 Speaking about what's possible with enough work.
https://engineswapdepot.com/?p=35398
Don't forget $$$$$$ and skill.
85 GLH, 367 whp
00 Insight, 72 mpg
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
WOW! Talk about overkill!
8,600 RPM on a 5 cylinder sounds glorious!
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Well... I guess it’s not overkill if you really want to push those quarter mile numbers down... :D
So, the block is good for at least 1200 hp. Good news for OP!
- S
[Sold] '97 S70 T5
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Sommerfeldt wrote: 24 Jan 2019, 00:12 Well... I guess it’s not overkill if you really want to push those quarter mile numbers down... :D
- S
And the moment the pedal is touched the entire rest of the drivetrain will destroy itself.
Sommerfeldt
Rattnalle wrote: 24 Jan 2019, 00:18 And the moment the pedal is touched the entire rest of the drivetrain will destroy itself.
I mean... just turn the engine sideways (longways?), switch out everything inside the block with new stuff, replace the drivetrain, make it rear wheel drive, replace everything outside the block, put a semi truck turbo on it, swap out the ECU...
The block's good, though. So... good news for OP! :D
- S
[Sold] '97 S70 T5
bmdubya1198
We all knew the 2.3 blocks could hold some serious power, but this is on the high end of the spectrum!
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The best bang for the buck is what I did to my 2001 V70 T5; a 2001-2002 LPT 2.4l engine mated with bigger T5 turbo and the T5 ECU is a perfect low budget power boost. Perhaps an engine from a 2003-2006 XC90 or 2003-2007 XC70?? The later engines have exhaust and intake VVT which can be left alone in your case. Just time them to the furthest clockwise point upon timing belt fitment. To avoid wear in the VVTs you could open them up and have an engineer weld the internals. This would prevent end-play and oil leaks.
In your case just put in a T5 turbo with associated plumbing (best to remove the engine for this) and T5 ECU for the engine.
The high compression engine from your XC (9 to 1 as opposed to 8.5 to 1) will give great bottom end and a good top end on premium fuel without detonation. Being a 1998 model you'll have zero problems with matching the engine computer to the car (unlike the 1999 and up models)
This combo will have more power than a 1998 V70R AWD due the the engine being higher compression and it will be noticeably smoother due to being from a later generation if you get one of the later engines.
Everything will be stock so part replacement will be a breeze.
I haven't seen any transmission kits that stop the Aisin auto transmissions from self-imploding whether they are the 4 or 5 speed. Manual transmission is the key here.
