Vida 2014D Times out 12/31/2017 23:59 Topic is solved
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
jkelley1083 wrote: 27 Jan 2019, 13:15 Yes and yes. All tests pass except Interface test. Says that “Self diagnostic connector is not attached”.
.NET Framework 3.5 installed?
2019-01-27 (1).png (33.6 KiB) Viewed 1967 times
Active
Past
jkelley1083
Year and Model: 2002 S60
Post by jkelley1083 »
RickHaleParker wrote: 27 Jan 2019, 13:34
Yes. Same exact setup as yours.
RickHaleParker
jkelley: Rerun the install process over the current install. That has fixed this problem in the past.
Active
Past
jkelley1083
RickHaleParker wrote: 27 Jan 2019, 15:25 jkelley: Rerun the install process over the current install. That has fixed this problem in the past.
I followed this advice and it screwed my stuff all up. It doesn’t “just work”. I used another method and it worked fine except for auto-detecting my DiCE. I followed your Installation instructions again for the repack and now VIDA won’t load anymore. Looks like I’ll have to erase everything and start from scratch..
RickHaleParker
You won't be the first that had to wipe clean and start over. That a Windows / IBM clone thing, they are all different hardware and software entities. Persecute it, your find your PC's demons.
Active
Past
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
RickHaleParker wrote: 28 Jan 2019, 06:27 You won't be the first that had to wipe clean and start over. That a Windows / IBM clone thing, they are all different hardware and software entities. Persecute it, your find your PC's demons.
+1
VIDA/DiCE is not a normal set up. I use Firefox due to its awareness and developer tools to find my way with newer installation. However, jkelley's frustration is right on with us DIYers. If I can turn it around anyone can.
Dr. Parker your patience is appreciated, don't know jkelley's set up, suspecting port 80 is in use.
jkelley1083
This is where I found the resolution to the black X problem I was having. If I had only found it before reinstalling over everything...
https://forums.swedespeed.com/showthrea ... 41?page=14
This method works PERFECTLY after downloading RickHaleParker’s repack and the 2099 patch
jkelley1083
TROUBLESHOOTING: PROBLEM: An X is presented in Internet Explorer were the DICE Communication tool selector should be (this happens after a Windows upgrade). SOLUTION: Locate on your VIDA DVD the directory D:\Install\Utils (substitute D: for your actual VIDA DVD location) and the file "EnableIEHostingx64.reg" and merge it with the registry by double clicking on it and then select "Yes" and "OK". For x86 systems do the same with "EnableIEHostingx86.reg"
xHeart
Post by xHeart »
jkelley1083 wrote: 28 Jan 2019, 07:55 This is where I found the resolution to the black X problem I was having. If I had only found it before reinstalling over everything...
Thank you for sharing jkelley. The link discusses "To resolve problems with non-detected or problematic DiCE-devices/USB ports...". It speaks to the issues that Rick identified in my Windows 7 Ultimate set up.
xHeart
Post by xHeart »
If you dot the i's and cross the t's, then that was a perfect guide!
