1996 Volvo 850 2.5L Automatic. Intermittent problems. Engine light and ABS light constantly illuminated, Service Light intermittent.
Gauge Cluster has 3 common problem scenarios:
EITHER
All works as intended
OR
Everything except the Speedometer and Odometer works
OR
All gauges bounce for a while, then settle into one of the previous two scenarios
Pulled the cluster once, cleaned all connections. Made no difference. No noticeable wire or terminal damage seen.
'96 850 Gauge Cluster Problems
- Has thanked: 2207 times
Usual issues are:
1) ABS module failure. This will affect the speedo, rev counter (possibly), and the odometer. Usually when the ABS module fails it will often trip the engine check light too.
2) Ignition switch failing. Try carefully wwiggling the key when car is running and see what happens. Naturally do this somewhere safe!
ABS module, Matty at Mid-West ABS is your friend here.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
And get those engine codes checked out.
Your Check Engine light probably has
messages stacked up for you.
The good news? If the service light just
comes on for two minutes when you start
the car, it’s only reminding you that you’ve
exceeded your mileage triggered service
interval. It can be reset and off ya go!
- 1506 Views
Last post by MDK
- 11 Replies
- 4388 Views
Last post by Faheyk1981
- 5052 Views
Last post by oragex
- 9 Replies
- 1982 Views
- 10 Replies
- 4041 Views
Last post by Maxoner22
