Volvo 850 power loss under hard acceleration Topic is solved
Jaumme
- Year and Model: Volvo 850 T5 1993
- Been thanked: 2 times
Y squeezed the return Lane And the pressure kept the same, i think the pressure rise when i start the engine is caused because the alternator is giving a little more voltaje than batery does?
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
That kind of brings us around to the pump again. Pressure should climb quickly with return line closed. If it doesn't that means replace pump.Jaumme wrote: 29 Jan 2019, 13:29 Y squeezed the return Lane And the pressure kept the same, i think the pressure rise when i start the engine is caused because the alternator is giving a little more voltaje than batery does?
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Pruned some posts that definitely were running low on lubricant.
Thanks for self moderating, people.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I guess that pdf narrowed it down.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sommerfeldt
Nice! Clemens got it spot on from the get-go.Jaumme wrote: 01 Feb 2019, 14:20 Just replaced the fuel pump today And no more Power loss.
Thank you all for the help
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Great! What do I winSommerfeldt wrote: 03 Feb 2019, 22:18Nice! Clemens got it spot on from the get-go.Jaumme wrote: 01 Feb 2019, 14:20 Just replaced the fuel pump today And no more Power loss.
- S
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Clemens
That is quite normal for a T5, maybe a bit low. The R models go a bit further. And my T5M goes a bit further as well, but then drops back immediately because it has boost spikes.Cookeh wrote: 07 Feb 2019, 08:39 That's about as far as mine goes on the boost gauge, so Id be interested in knowing if its normal too!
you can always shorten the wastegate rod a bit (by like 1-2 turns the max.), but be careful because you can cause harm. Use a vac tool to set the base value of (I think) 1.8 psi for the M4.3 T5s and then shorten by about a turn. This wakes up the brick at low rps/speeds.
Please do some reseearch, I am writing based on my (confused) memories.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 878 Views
Last post by Jaumme
- 1572 Views
Last post by jjlch
- 940 Views
Last post by Hardtofool
- 914 Views
Last post by bmdubya1198
- 4706 Views
Last post by June
