I got an '89 Volvo 240 DL wagon back in September that had been donated to charity and went to auction. I towed it back home, not knowing much of anything about what I had purchased.
I had an auto shop go over it and they've found some repairs that need to be made, and one is very urgent.
He's trying to source the parts but doesn't know what he's seeing online. He doesn't see a 240 DL model that's listed, but rather a 244. Is this the same parts?
The parts I need for it are:
Steering Shaft (it's cracked)
Power Steering High pressure line (leaking)
Water Pump (leaking)
Can anyone help me out? Thank you so much!
'89 Volvo 240 DL Wagon---parts sourcing woes
shutterbugpaul
- Year and Model: 1989 Volvo 240 DL Wg
- RickHaleParker
- Been thanked: 979 times
Run the VIN number through the Volvo Vin decoder and find out what you got. List the information here.
Active
Past
Past
shutterbugpaul
ok, I hope this helps.
- RickHaleParker
Water pump comes as a kit and the Volvo part number is 271975.
Lower Steering shaft, piece between the two universal joints, is Volvo Part number 1229209.
Upper universal joint Volvo part number 1359403.
Lower universal Joint Volvo part number 6819550.
Power Steering Pressure hose: Volvo Part number 1359461.
If you want to pay only once in your lifetime for quality parts, buy from FCP Euro. Lifetime warranty.
Second parts source IPD+.
Active
Past
Past
shutterbugpaul
Thank you so much! It seems this car was called the 244 model most frequently. Was the 244 the more common sedan where the wagon was the 240? Or...?
The auto mechanic shop just told me steering shaft. I should ask if he's meaning the whole thing (those 3 parts) or which specific section, right?
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
240 was the series....242, 244, and 245 were models from previous years....in later years, all were called 240s...see rear of your vehicle...240DL.
240 or 245 is typical nomenclature for your vehicle....245 connotes a station wagon.
Normally, when replacing water pump, a timing belt set is also replaced.
- RickHaleParker
Not officially.shutterbugpaul wrote: 29 Jan 2019, 20:28 Thank you so much! It seems this car was called the 244 model most frequently.
1975–1979: Format: Trim letter in front followed by 2XY.
Where: 2 = 200 series, X = the number of cylinders, Y = doors.
X = 2 Coups, Y = 4 Sedans, Y= 5 wagons, Exception: 242 are two-door sedans.
1980–1985: trim level letters followed by 2X0, The Y destination was dropped.
Exceptions: A small number of 260s had four cylinders and a 240 could have six cylinder diesel.
1986–1993 Format 2X0 followed by the trim level.
Your car is a 1989 240 DL wagon (de Luxe). You got the title correct.
If it had been a 1975–1979 it would of been a DL 245.
Active
Past
Past
- 1961 Views
Last post by SonicAdventure
- 14 Replies
- 3573 Views
Last post by oragex
- 746 Views
Last post by oragex
- 10 Replies
- 1763 Views
Last post by bmdubya1198
- 992 Views
Last post by matthew1
