Re: the short. If I take the +ve battery cable off. I can read 12 V, when I touch the +ve battery terminal and the +ve battery cable (that is off). I can also measure conductance between the +ve and -ve wires, when both off. I pulled EVERY fuse one by one and did not find a change in the condition. I could always read 12V btw +ve terminal and +ve wire (while off). This makes no sense to me. I can't see any physical damage to the wires that power the fuses boxes, but also, because there are so many boxes, I can't be sure that I checked all. Anybody can provide an electrical diagram of how the power reaches all the fuse boxes. Of course, it's possible that more than 1 circuit is affected hence there is no V drop when I just pull one fuse at a time. Any suggestions would be appreciated. I had nothing but bad luck with this car
Thanks
