Volvo S70 T5 automatic gearbox
misha
Has thanked: 152 times
Been thanked: 402 times
Re: Volvo S70 T5 automatic gearbox
Post by misha »
Nope....you will need at least Vol-fcr.
Ecu M4.3 is practically obdI since it still produce flash codes along with ecc.
Other modules are fully OBDII including transmission.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Gouws
Year and Model: Volvo S70 T5 1998
Post by Gouws »
Hi could it be the solenoids that maks my automatic gearbox slip.....should i let the car be pluged after taking out the gearbox and puting it back.
Gouws
Post by Gouws »
Also whant to know volvo automatic transmission 1998 S70T5 does the gearbox work whith bands inside or not
Gouws
Post by Gouws »
I took the gearbox out and putted other clutch plats.....and put it back......but still slipping if i drive from brakpan to spings halfway.....when i turn eknision on and off again it sounds like a sollenoid is stil on.chould it do that
Gouws
Post by Gouws »
Also whant to know volvo automatic transmission 1998 S70T5 does the gearbox work whith bands inside or not.im planing to take out the gearbox tommorow i wich that i dont have to already done that twise now will be the thurd time
Gouws
Post by Gouws »
scot850 wrote: 26 Jan 2019, 12:16 As the oil warms it starts to become thinner. Don't worry about the spelling as my Afrikaans is non-existent so I appreciate your helping me with english!!
From what I read above you have an auto trans (4-speed auto). I believe you have change the valve bodies possibly or do you mean the clutch plates in the trans itself?
How did you change the oil in the transmission? We always recommend you never use a machine and power flush these older cars as it tends to loosen the old dried oil from the inside of the casing and it gets into the valve bodies and clogs the valves which make the gears slip or not work at all.
What transmission oil did you use?
Hi Niel sorry for deley.i put dex two
Gouws
Post by Gouws »
And i done the clutch plates itself inside the gearbox
Gouws
Post by Gouws »
Can somebody please tell me i dont have to take out my automatic geatbox ttomorow.please let me know.if any one can help me with advice
Gouws
Post by Gouws »
Is there anybody that can gif me advice on my volvo s70 t5 1998 automatic transmission please.its slipping.....i done few things but stil slipping after 1or 2 km of driving....then have to switch it of for few min then only can it go again
Has thanked: 1850 times
Been thanked: 1710 times
Do you have the owners handbook with the car? I believed the correct oil for your transmission is Dex3 not 2.
