1998 V70XC P0304 (Cylinder 4 Misfire) Under Hard Acceleration
bubbeck
Year and Model: 1998 V70XC
Post by bubbeck »
Hey fine folks,
I've been having some trouble with my 98 V70 turbo wagon stumbling and misfiring under hard loads and acceleration lately. Normal around town driving is fine, even most highway, but when accelerating hard up long hills the engine stumbles and rpms drop slightly. This problem finally got bad enough today to throw a blinking CEL P0304 (Cylinder 4 misfire.) I pulled the plugs (NGK 6962 coppers, see pic) and while none looked terrible in my opinion, the gaps were all .033 - .037 (put these in ~15k miles ago). I plan to throw some new Bosch coppers in and see how it goes, but any other ideas for what could be going on here? I replaced the fuel filter recently (after this problem started though) and did a compression test about a year ago - ~163 psi on 4, ~170 on the rest. Cap/rotor/wires are bosch, probably about 50k miles in. Thanks!
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Wires should be Bougicord genuine. Bosch can get wires (and oil filters in my experience) terribly wrong.
Nothing I've read has confirmed a happy Bosch spark plug wire customer long term. Can you swap one of the other cylinder wires over and see if the misfire moves to another cylinder?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
As far as i know...spark plug gap on turbo car should be 0.028 and it's critical.
Being a turbo car....you could have some large vacuum leak which reveals itself only at wot.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1611 times
Been thanked: 4075 times
Gap of 0.028 is important and has to be set on new plugs
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
A gap of "0.037" is way out of spec. New copper plugs gapped to 0.028 would be a good diagnostic start. A new compression test would not be a bad idea either.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
bubbeck
Post by bubbeck »
I definitely gapped the plugs to .028" when I put them in a year and a half ago, wonder how they grew so much... Will throw some new ones in and report back! If that doesn't solve it, would y'all move on cap/rotor/wires ($100, easy), vacuum lines ($40, more work), or servicing/replacing injectors ($100-$150, easy) next?
Boost
:D
bubbeck
Post by bubbeck »
Hehe probably :) Ran a cold, dry compression test today, and got 170, 165, 170, 155, 170 on cylinders 1-5. So cylinder 4 (the misfiring one) is a bit weak but 155 psi still seems fairly ok no? Still within 10% for what its worth. I ended up pulling the distributor cap when I put in new plugs, and there was a good bit of oxidation on the cap contacts. Unfortunately while brushing them, I knocked the center brush out, then managed to lose it so guess I'm doing cap/rotor/wires now too anyway.
WhatAmIDoing
A warm compression test and especially a leakdown test will identify if cylinder 4 has bad rings. Under heavy load it may not be maintaining compression.
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
Seems that most of your driving is at low rpm. Try driving in 2nd around town, keeping the rpms above 2000, to clean off the valves. Besides, it makes for a lot of fun driving!
I am surprised that the CEL blinked, that usually only happens when more than one cylinder is misfiring.
Klaus
