Front End Creak/Squeak
Tinwood
Year and Model: 1996 850 GLT
Post by Tinwood »
I am starting to notice a creak/squeak/groan in the right front of the car ('96 850 GLT). Always when travelling over a rough surface. It has the sound of a rubber bushing or something similar. Could this possibly be a sway bar bushing or a control arm bushing? Maybe something related to the strut? How do I diagnose?
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
Probably a strut mount spring seat, quite common. Take a large wrench or pliers and try to turn the large nut at the top of the strut (in the engine bay) clockwise. If it resists turning or moves back to its original position, then it is in good shape. If it turns easily, then the spring seat needs to be replaced - use a heavy duty spring seat or one for an XC90.
Klaus
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
As above. Arb bushes being worn can also produces knocks when going over undulating surfaces.
Has thanked: 312 times
Been thanked: 818 times
When replacing the spring seat, the key is the manufacturer, not how the part is described. The XC90 spring seat and the 850 spring seat are the exact same part number from Volvo, neither is more or less heavy duty than the other. Buy the part from Volvo is still my recommendation.
Tinwood
Post by Tinwood »
Thanks all. Will wait until it is warmer than the current -35 wind chill to inspect.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Control arm bushings can also make those strange noises when they become dry.
A bath of wd-40 usually quiets them.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
