Can a FWD transmission be converted to work with AWD
I hope this doesn't sound like a dumb question, but I have a very low mile transmission from a FWD S60 and I'm hoping I could somehow make it so a transfer case could bolt up to it and use it in an AWD car. So will it work or is there no way to convert it?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
No. The final drive for FWD will not have the splines to drive the angle gear. The FWD case has a small opening for RH axle that i too small for the AWD collar. If the FWD trans is similar year and from a turbo engine car it will have the same internals and gearing and could be put in the AWD case and use the final drive from the AWD trans.
That's what I figured, thanks!jimmy57 wrote: 03 Feb 2019, 21:00 No. The final drive for FWD will not have the splines to drive the angle gear. The FWD case has a small opening for RH axle that i too small for the AWD collar. If the FWD trans is similar year and from a turbo engine car it will have the same internals and gearing and could be put in the AWD case and use the final drive from the AWD trans.
It is, minus the transfer case. However there are holes on the FWD for the transfer case to bolt up to. But like jimmy said, the shaft is smaller.cn90 wrote: 03 Feb 2019, 20:35 For some reasons, I thought the Trans is the same for both FWD and AWD versions?
May be I am wrong...
Daveliz99
- Year and Model: V70 2001
- Has thanked: 3 times
- Been thanked: 2 times
Here is a link to a thread where a guy says he did make the conversion. He says he went from a 5 speed auto, apparently in an AWD car, to a M56 from a FWD car. It’s the last post in the thread.
viewtopic.php?p=484461#p484461
Yes, both turbos.
Thanks, that's good information.Daveliz99 wrote: 04 Feb 2019, 18:13 Here is a link to a thread where a guy says he did make the conversion. He says he went from a 5 speed auto, apparently in an AWD car, to a M56 from a FWD car. It’s the last post in the thread.
- 3931 Views
Last post by kirklewis
- 7971 Views
Last post by EddieRiff
- 2002 Views
Last post by Lelica
- 2528 Views
Last post by RickHaleParker
- 11 Replies
- 15783 Views
Last post by June
