Kallekula's 2001 Wagon Relapse Topic is solved
That’s all right. It’s more important that they are close than exactly at spec , I’ve read
Probably top end from a timing belt failure?
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Yeah I guess. Timing belt has wear on outside, really not sure what’s going on. Belt maybe jumped a few teeth? I’m not gonna speculate very much, just pull the head off and see what’s going on.abscate wrote: 05 Feb 2019, 04:07 That’s all right. It’s more important that they are close than exactly at spec , I’ve read
BMW 540i 2002
S70 Base 2000
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
ZERO compression......that's interesting. I'd like to hear more about what's happened here. An old non-interference engine with a broken timing gear or similar will do that because the valve train isn't moving. But there might be one valve shut somewhere and you'd get a number.
- SuperHerman
- Been thanked: 207 times
Sounds like you did a compression test. Did you also check the timing?
It is possible, but doubtful, it is out of time. Still worth the work to double check your marks. I suppose someone may have had a bad pulley or tensioner - just replaced that and screwed it up. Checking the timing would eliminate this scenario.
Most likely, as speculated, the timing moved/belt broke and bent some valves. Someone may have put a used belt on to see if they got lucky or readjusted the belt/pulleys, learned they did not and sold it to your careful hands at a next to nothing price. What did you pay?
- kallekula
Yeah I was thinking checking the timing before I tear it apart. Guy who sold it seemed honest, worked as a diesel mechanic and did the head 10k miles ago. Paid $500SuperHerman wrote: 05 Feb 2019, 11:12 Sounds like you did a compression test. Did you also check the timing?
BMW 540i 2002
S70 Base 2000
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
They look quite skinny for 215/65-16s which iirc is the correct size.
Looks really nice otherwise. Nice climate for the cars I guess. Some work on the black plastic and it'll look like new.
After you've found the whole compression issue ofc
- 43 Replies
- 6270 Views
Last post by bmdubya1198
- 32 Replies
- 9393 Views
Last post by mayorpeoria
- 19 Replies
- 4579 Views
Last post by kallekula
- 1288 Views
Last post by Fred Trotman
- 931 Views
Last post by manovlov
