IPD sale Volvo Parts
Did you know? 🤔
XC90 Key transponder failing.
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
donnymol
Year and Model: 2012 xc90
Has thanked: 0
Been thanked: 0
United States of America
donnymol
Post by donnymol » Wed Feb 06, 2019 8:19 am
I have seen that others have this issue as well. My car is 2012 xc90. It intermittently wouldnt start, but last night and this morning i am having no luck. The dealership is telling me its about $400 for a new key + tow. Has anyone else found a more reasonable solution?
Has thanked: 0
Been thanked: 70 times
Re: XC90 Key transponder failing.
Post by cn90 » Wed Feb 06, 2019 9:14 am
Happened to my 2005 XC90 key.
Keep the FOB, if you replace ONLY the key portion, then about $250.
I posted some info in forum.
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Has thanked: 0
Been thanked: 41 times
ggleavitt
Post by ggleavitt » Wed Feb 06, 2019 10:46 am
As a point of clarification, engine turns over with the key but does not start or does not turn over at all? And you have only one key so cannot compare against another?
2005 2.5T AWD-194k
2008 V8 AWD Sport-124k
donnymol
Has thanked: 0
Been thanked: 0
donnymol
Post by donnymol » Wed Feb 06, 2019 12:10 pm
yes. i only have the one key.
no, the engine does not turn over. i get the error of start failed, try again.
someone in my IT departmment thinks the circuit may be damaged. they are gonna try and check it today and see.
Has thanked: 0
Post by cn90 » Wed Feb 06, 2019 12:27 pm
Do you have a second key, which makes diagnosis very easy.
This was my case...I used the second key for diagnosis.
donnymol
Has thanked: 0
Been thanked: 0
donnymol
Post by donnymol » Wed Feb 06, 2019 1:11 pm
Yea, just the one key. I am pretty sure its the key/circuit/transponder. I am just seeing if there is another solution rather just buying a new key from the dealership
hebhere
Year and Model: 2005 xc90 tr6
Has thanked: 1 time
Been thanked: 0
hebhere
Post by hebhere » Thu Feb 07, 2019 2:41 pm
Both of my Key Fobs need programmed. The key works, not the remote. I do have a Valet Key also, which is what I use. At the my friend's shop, where I help him at times, we can get every key re-programmed for about $100.00, some we are able to do ourselves. But, not the Volvo Key Fob......Nope, Volvo has that locked in. I was told by the dealer $350.00 per fob. What is bad is it only takes a few minutes to do.........Been living with it this way..... Will continue to do so unless I win the lottery.
yagger
Year and Model: S60 2005 2,5T
Has thanked: 1 time
Been thanked: 5 times
Belarus
yagger
Post by yagger » Sat Feb 09, 2019 1:24 pm
We can unlock remotes. After this procedure you can program it to car, use official VIDA or we can program it use our own methods.
We know how to repair electronics and programming Volvo. Yagger&Doublebug - our experience invaluable.
jimmy57
Has thanked: 1 time
Been thanked: 144 times
jimmy57
Post by jimmy57 » Sat Feb 09, 2019 10:04 pm
By any chance does the key NOT stay latched 180 degrees from the folded stored position? If the key doesn't stay latched then the chip can be out of range when the remote folds over at 90 degrees to key.
