- Has thanked: 1611 times
- Been thanked: 4075 times
Missing my T5 patiently waiting for me in the EWR airport back in NY....
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I've always been a bit confused with what are the proper spark plugs for the T5. I see lots of recommendations for Bosch coppers gapped to 0.028", but the manual states the gap for turbos is 0.030":bmdubya1198 wrote: 07 Feb 2019, 08:55I've had good luck with Bosch Coppers, which are recommended on Volvospeed. I believe they are FR7DC. No need to spend extra money on iridium or platinum. I'm much happier with how my V70 runs on the coppers than the platinums that were in there.Cookeh wrote: 07 Feb 2019, 07:44 Looked through its history trying to see when the plugs were last changed... Can't see any evidence they ever were at all! What is the recommended replacement for the T5? Seen several threads on here with so many different answers, with the only real reoccurring comment being the gap - 0.028" iirc.
Car is on 185k and does sound 15k a year, so presume platinums are better then copper in this scenarios? Would the Denso pk20pr-p8 be suitable? Or should I be looking at the NGK BKR7EVX which according to SKANDIX at least are the OEM?
Champion RC8PYP cross references to Bosch FR7DP which are the plugs currently in my T5, running happy.Distributor ignition system
Firing order 1-2-4-5-3
Distributor ignition setting Not adjustable
Spark plugs Bosch FR 7 DC or Champion RC9YC
Spark plug gap 0.028" (0.7 mm)
Turbo-charged models: Champion RC8PYP (or equivalent)
Spark plug gap 0.03" (0.75 mm)
Tightening torque 18.4 ft. lbs. +/- 3.7 ft. lbs. (25 Nm +/- 5 Nm)
Why does everyone recommend a gap of 0.028" regardless if turbo or NA? I've never seen anyone actually explain this. Is the manual wrong?
Knows enough to be dangerous
- June
- Has thanked: 523 times
- Been thanked: 261 times
Are you driving a non Volvo rental car? I was just 15 days without my T6 and I had withdrawal symptomsabscate wrote: 07 Feb 2019, 18:27 Missing my T5 patiently waiting for me in the EWR airport back in NY....
Have a safe trip, June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
Im in SF so its Uber, Lyft, or BART for me. No $60 parking bills, thank you very much.
Hotels in SoMa are $499 so Im staying with friends in Tiburon
How much Lyft Credit is a gallon of used oil worth?
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
It seems both the NGK BKR7EVX and Denso PK20PR-P8 also cross reference the Champion RC8PYP (which is now unavailable in the UK), so in theory as long as correctly gapped either those or the Bosch FR7DP would appear to be suitable? If so I guess the recommended spark plug is then just the cheapest!WhatAmIDoing wrote: 07 Feb 2019, 18:45I've always been a bit confused with what are the proper spark plugs for the T5. I see lots of recommendations for Bosch coppers gapped to 0.028", but the manual states the gap for turbos is 0.030":bmdubya1198 wrote: 07 Feb 2019, 08:55I've had good luck with Bosch Coppers, which are recommended on Volvospeed. I believe they are FR7DC. No need to spend extra money on iridium or platinum. I'm much happier with how my V70 runs on the coppers than the platinums that were in there.Cookeh wrote: 07 Feb 2019, 07:44 Looked through its history trying to see when the plugs were last changed... Can't see any evidence they ever were at all! What is the recommended replacement for the T5? Seen several threads on here with so many different answers, with the only real reoccurring comment being the gap - 0.028" iirc.
Car is on 185k and does sound 15k a year, so presume platinums are better then copper in this scenarios? Would the Denso pk20pr-p8 be suitable? Or should I be looking at the NGK BKR7EVX which according to SKANDIX at least are the OEM?Champion RC8PYP cross references to Bosch FR7DP which are the plugs currently in my T5, running happy.Distributor ignition system
Very interesting regarding the gap, that's an excellent query.
- June
+1 JuneRattnalle wrote: 08 Feb 2019, 01:27 Spark plugs come in a blue package that says Volvo and models they fit on it..![]()
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- Cookeh
Yes, but if I go to Volvo (60 mile trip) they'll charge me £55 for spark plugs. Now if those spark plugs are Champion RC8PYPs, then I can buy those for £30 delivered. If we're talking compatible spark plugs like the FR7DP, then I can get those for £20 delivered. The equivalents from NGK would cost me £12. Potentially significant savings to be had here, especially if they all perform equally due to having the same composition and same core thickness equating to the same ohm resistance and temperatures. Hence the dilemma, and the query.
