HAVE A 2007 VOLVO S80 4.4 AWD. NEED A TRANSMISSION FOR IT. WHICH ONES WILL FIT? WILL THE 3.2 AWD HAVE THE SAME TRANS? ANY HELP WOULD BE GREAT! I REALLY ONLY NEED THE TRANS PUMP BUT UNDERSTAND IT'S NOT SOLD SEPARATELY SO I NEED THE WHOLE TRANS.... EVEN NON VOLVO IF ANYONE KNOWS IF ANY OTHER GM CAR HAS SAME SET UP?
THANKS
DAN
What transmissions fit? 2007 S80 4.4 AWD
goldmandan
- Year and Model: 1999 S 70, 2000 V70
Reason: Improved title. Please, only one question mark is needed.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Your transmission is not the GM supplied one. It is an Aisin-Warner, a mostly owned subsidiary of Toyota, transmission. XC90 V8 is the same transmission. I do not know if the pump is the same as other Volvo models using the TF80-SC transmission. All Volvo models with 6 speed automatics are that unit. The bell housing differs, 6 cyl, 5 cyl, and V8 bell housings all differ.
goldmandan
OK PERFECT SO ANY 4.4 EQUIPPED S80 OR XC90 WOULD BE THE SAME! PERFECT. I THOUGHT MAYBE THE 3.2 WOULD FIT..... I AM ONLY REALLY NEEDING THE PUMP BUT NOBODY SELLS IS
DAN
DAN
- 9 Replies
- 1822 Views
Last post by vtl
- 1684 Views
Last post by precopster
- 1392 Views
Last post by Tsquared
- 19 Replies
- 3360 Views
Last post by 850TurboTurtle
- 1677 Views
Last post by FLXC90
