pitted brake disc
enotslim
Year and Model: 2004 XC70
Has thanked: 71 times
Been thanked: 16 times
Post by enotslim »
New rear brake pads (Autozone ceramic) 6 weeks ago. Felt mild pulsation I thought was rust that diminished but did not entirely disappear with time. Now about 1 week of increased (but still pretty mild) pulsations. Yesterday I found pitting of the LR disc as shown in the attached photo. Clearly need new discs. Do I also need new pads? I will probably install new pads regardless but just wondering if the pad is likely damaged from mating to the pitted disc.
Plan Akebono pads and AKE discs.
Thanks
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Inspect pads for uneven wear. Also possible (I have never used Autozone ceramic pads), but they may be too hard for the brake disks and are chewing them up. IMHO, Akebono ceramic pads are the best and a worthy upgrade.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Did you "bed-in" new brakes and pads?
Every time you install just pads or both...disc & pads...you need to perform "bedding-in" procedure...or to use brakes carefully and gently for first few hundred miles.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
enotslim
Post by enotslim »
I did the 5 stops from 40 to 5 mph without cooling, then 5 from 20 to 5 with cooling. Didn't smell resin though. Driving is all city so there is some unpredictability, but I also usually drive when few are on the road (4:30 am and 7-8 pm) so it is pretty tame.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
Rotor is doing it. Whenever I put a used pad that's grooved or glazed on a new rotor I lay a piece of sandpaper on a table and rub the pad on it until it has a new flat surface. Been doing this for years and never a problem.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
enotslim
Post by enotslim »
The pads were new, not the rotor.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I have the Akebono pads and my genuine discs don't wear like this. Maybe it's the discs, but I also have another rather wild idea.. when installing the new pads, did you push the pistons back without releasing the caliper bleeder? There is a small chance this would get the solenoids inside the ABS valve body slightly stuck and reduce the rear braking pressure which may cause such wear as well.
misha
Post by misha »
I always push pistons back in without loosening bleeding bolt...that's how they supposed to push back..otherwise you will let air in the line.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
oragex
Post by oragex »
When loosening the bleeder bolt, I put over it a small plastic tube sitting tight, about 50cm long going into a can.
Indded, most of the times nothing will happen, but it is possible the back pressure to lock a solenoid inside the ABS body. But in any case, I like to open the bleeder because it's a good moment to bleed the fluid and it also makes pushing back the piston easier. It also helps keeping this bleeder 'removable', when left in there for long time it can get badly stuck.
enotslim
Post by enotslim »
greg850r wrote: 10 Feb 2019, 13:37 Rotor is doing it. Whenever I put a used pad that's grooved or glazed on a new rotor I lay a piece of sandpaper on a table and rub the pad on it until it has a new flat surface. Been doing this for years and never a problem.
The pads were new but thanks for that suggestion. Makes lots of sense.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
