Steering, how to check by Volvo procedure.
zegers
Year and Model: 2001 V70XC 1999 v70
Re: Steering, how to check by Volvo procedure.
Post by zegers »
oragex wrote: 10 Feb 2019, 06:43 Was the inner tie rod replaced on that side? When these are being replaced, the inner centring bushing can fail upon torquing the tie rod, if the rack bar is not counterhold (Volvo has a special tool for this). Not always but may happen. Anyhow, you need a replacement rack so look for a used one if keeping the car - and its a good job, several hours. 'Refurbished' racks may or may not be good
Oragex, You are right about the left inner tie rod. I can see wrench marks on it, probably was not counter hold and the bushing was damaged.
I have seen a new AAE steering rack at RockAuto for about $310 US. I think I go that way.
537playing
Year and Model: 2005 S60
Been thanked: 5 times
Post by 537playing »
Go to a different shop for your inspection. I find that some people aren’t skilled to perform their jobs and give answers like the one you got.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
I'm curious if you lifted each wheel, one at a time, from under the lower control arm/ball joint. That way you would be analyzing with the suspension and tie rod in a close-to-normally-loaded position.
zegers
Post by zegers »
chrism wrote: 16 Feb 2019, 16:48 I'm curious if you lifted each wheel, one at a time, from under the lower control arm/ball joint. That way you would be analyzing with the suspension and tie rod in a close-to-normally-loaded position.
No play if tested in a close to normally loaded position, that's why I started this post.
I think the mechanic (the owner of the business) who started doing safety inspections just a year ago, is too insecure.
This is what makes the car fail inspection:
ONTARIO Passenger / Light-Duty Vehicle Inspection Standard
Reference Handbook
October 2015
for rack and pinion steering systems there exists excessive free play in the steering mechanism
zegers
Post by zegers »
537playing wrote: 16 Feb 2019, 16:24 Go to a different shop for your inspection. I find that some people aren’t skilled to perform their jobs and give answers like the one you got.
I was thinking about that, but this shop is close to me. I cannot get licence plates before the car passes safety, and I don't want to go on the road without plates and insurance.
I had to pay for the inspection already. Going to a different shop would cost me $110 again, and who knows what they would find.
I decided to put the money in a new rack. I am waiting on the two O rings, than I will put the rack in and he will have to write the safety.
chrism
Post by chrism »
Sounds like the problem isn’t so much the rack as it is the racquet.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Side note, I'm in Quebec province, no mandatory inspections here (other than if a cop has a suspicion when a car gets pulled for some reason). I know for sure many cars are in pitiful condition here - i remember a Chrysler Caravan on a lift at a garage, it only had a few inches of the top and lower end remaining off the rear shock absorbers (the rest did melt from rust)
On the other side, these inspections sound pretty scary, and may also trigger owners to put cheap parts upon selling their car. But I guess it also helps most cars be in better condition when they come up for sale (suspension/steering wise)
zegers
Post by zegers »
chrism wrote: 17 Feb 2019, 12:44 Sounds like the problem isn’t so much the rack as it is the racquet.
What is a racquet?
Has thanked: 1504 times
Been thanked: 3817 times
Play on words , orange
Racket is a word for a someone scamming or not being up front
chrism
Post by chrism »
abscate wrote: 17 Feb 2019, 18:38 Play on words , orange
It would help if my phone and I would spell it right.
