Kallekula's 2001 Wagon Relapse Topic is solved
DOHC on the cover is Swedish for colour matched mirrors.
- SuperHerman
- Been thanked: 207 times
My guess, if all the pulleys rotate well and were properly torqued down, is the belt walked. I say this because of the belt wear. On my V50 I had a belt walk caused by the crank gear coming out. Fortunately it was caught before major damage occurred.
On yours, I speculate after the belt walked it got caught up in the tensioner and shredded and bent the timing guide.
I assume you don't have an engine belly pan on your car as this would have stopped a foreign object from entering the engine area.
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Pulling the head to assess the damage this week. I only measured compression on # 4 & 5 after timing was reset and it was zero. Might be cheaper to pull a head from the junk yard and give to the machine shop so I dont have to shell out for all bent valves. Head is only around $60 and next weekend is 40% off.
BMW 540i 2002
S70 Base 2000
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Sounds like a plan.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- kallekula
So I was planning a trip to lkq pick your part to get a head that would hopefully be in better condition than the one I have. Then came the rain and when that happens all Californians including me hide inside and expect the worst.
Last night I came home with one hour of daylight left expecting to pull the head. I started draining the engine oil just to find out the drain plug is cross-threaded and does not seal. Great I’ll drop the pan then. Dropped the subframe but there must be a way to deal with that without taking the pan off, I’ll investigate. While contemplating that I did one AT drain. Think it’s safe to say it was never replaced within the 106K this car has been on the road. Absolutely filthy and I’m praying the internals are still ok with that junk flowing around in there.
BMW 540i 2002
S70 Base 2000
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
Xheart and I recently dropped and cleaned the oil sumps on our XC70s. Only removed parts are splash shield, trans mount, oil cooler, and fuel line bracket. After dropping the rear side of oil sump from trans you get the front off by angling it through the subframe.
- kallekula
Yes I dropped oil pans before but for other reasons. I’ll see if there is a possibility to get a helicoil in there.XC70Rider wrote: 19 Feb 2019, 10:26 Xheart and I recen and cleaned the oil sumps on our XC70s. Only removed parts are splash shield, trans mount, oil cooler, and fuel line bracket. After dropping the rear side of oil sump from trans you get the front off by angling it through the subframe.
BMW 540i 2002
S70 Base 2000
- kallekula
Drain plug problem sorted! The drain plug that came with the car didn’t look like oem, kind of short also. Went to a hardware store and found a longer bolt. Worked like a charm, one problem less to deal with.
BMW 540i 2002
S70 Base 2000
- kallekula
Had a little bit of time with the car after work today. Put subframe back and also put in new transmission fluid to compensate what I drained.
Worthless old drain plug New huge drain plug. Think it’s like 26mm! New vs old fluid
BMW 540i 2002
S70 Base 2000
- 43 Replies
- 6258 Views
Last post by bmdubya1198
- 32 Replies
- 9362 Views
Last post by mayorpeoria
- 19 Replies
- 4572 Views
Last post by kallekula
- 1287 Views
Last post by Fred Trotman
- 929 Views
Last post by manovlov
